Rotors and pads
Rotors and pads
I have a 2011 3.0 tdi s line and my front Pads are getting down and Audi said the rotors need changing too , I think Audi want around £515 for this (UK) , my local independent can fit aftermarket front Rotors and pads from £250 to £300 depending on quality so quite a saving but is it false economy are genuine Audi worth the extra ?
If not which after market brand should I go for ?
Thanks in advance for any advice
Do you know what brand rotor they are suggesting? In the US, there are Bosch and Zimmerman available, along with a third brand that I don't think I'd use. I don't know if Brembo is making the rotors along with the calipers or not.
For pads, I've run Pagid (endurance race yellow), Textar and Jurid pads on 993 calipers on one of my other Audis. I liked the Pagids the best, which happen to be the OE.
Front rotors and pads would be a breeze on these. The rears would be a little more tricky due to the drum-in-hat park brake assembly. DIY the fronts and save even more sterling.
If you buy from Eurocarparts or CarParts4less (both the same company) you will get a choice of brands and prices accordingly.
I fitted Pagid pads which are OEM pads but they do squeal at low speed when warm. Most from them should be OK and your independent mechanic will probably buy from them anyway - they deliver nationwide - many areas have same-day service.
Audi A8 FEELER: 2007 S8
gpinkwater
17
09-01-2016 09:07 AM
Audi Other 6 speed 2003 Audi RS6
alpinab7
10-07-2015 10:13 PM
Gzila850
09-29-2015 01:32 PM
