Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 S-Line with AMI - defiantely no analogue AUX?
Old 10-10-2011, 10:12 AM
ouroboros's Avatar
Default Q7 S-Line with AMI - defiantely no analogue AUX?
Hi Guys,
I'm familiar with the MOST type fibre bus our cars have from Porsche.
My 2008 with AMI doesn't have the iphone cabability so I was looking at the documented retrofit or dension.
However I just wanted to double check there is definately no analgue AUX on the cars? Given that this would be an expensive upgrade just for integrated control - the touchscreen control for songs on an iphone is better anyway.
Cheers,
Old 10-10-2011, 10:22 AM
ouroboros's Avatar
Hidden Menu
VAG-Com
http://audiforum.us/threads/aux-in-f...-system.12768/
anyone done this on a Q7?
The advantage here is that if you use AUX on an iphone, it doesn't disable toe iphone user interface (which it does on my MB iphone adaptor). Would be a perfect solution with a proclip type OEM looking mount.
pleeeezzzzzeeee let it be?
Old 12-31-2011, 09:08 AM
ouroboros's Avatar
Hi,
With a little more investigation - It turns our on a Q7 there are two AV inputs on the MMI available as standard on the menu.
There is a 20 pin audi connector in a controller on the rear right of the trunk. Would be grateful if anyone has a pin out for this? I'm just looking for the audio channels to run a 3.5mm headphone cable from an iPhone.
Cheers,
Old 04-04-2014, 10:39 AM
Matt@H2OTuning's Avatar
Originally Posted by ouroboros
Hi,
Cheers,
Did you ever figure this out?
P549RR1
Q7 MK 1 Discussion
09-19-2012 06:56 AM
hockeypuck
VAG-COM Discussion
04-08-2007 05:00 AM
urS4guy
Audi Original "S" Cars
06-06-2006 02:57 PM
efudd105
04-07-2004 07:23 AM
Quick Reply: Q7 S-Line with AMI - defiantely no analogue AUX?
