Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Sunroof Noise
Old 04-16-2014, 06:52 PM
Matt@H2OTuning's Avatar
Default Sunroof Noise
Is it common to hear a lot of wind noise while the sunroof is closed? Have had many vehicles with one and never heard this much noise. Luckily I haven't had any leaking issues like I have seen in other post.
Old 04-17-2014, 12:13 AM
Edd W's Avatar
I have not noticed any wind noise at all.
Can you tell if it is from the front or rear section?
Does it worsen if you lift very slightly with your hand while travelling?
Old 04-17-2014, 12:17 AM
Edd W's Avatar
Default I have not noticed any wind noise at all.
Old 04-17-2014, 06:06 PM
Front section. Haven't tried lifting it while driving but I will.
Old 04-18-2014, 01:59 PM
Edd W's Avatar
It sounds like either the glass is not adjusted correctly, a seal is missing or damaged or the carriage mechanism is damaged or similar. Open it fully by holding the **** fully rotated to move the glass back as far as it goes then have a good look at the seal and check the glass is fixed properly to the runner mechanism.
Old 04-18-2014, 03:47 PM
B490MTL's Avatar
Also it helps to put some silicone lube on a rag and rub it on the rubber seal.
Old 04-19-2014, 05:01 AM
Did this today and it got noticeably louder.
Thanks! I will try this out today!
Asarge
18
01-11-2018 09:28 AM
Glacier6
A7
02-18-2016 03:45 PM
imarch
Audi allroad
02-01-2005 05:42 AM
Billy531
07-23-2003 04:51 AM
audi231
07-15-2002 03:28 PM
Quick Reply: Sunroof Noise
