Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Timing Chain?
Old 01-11-2017, 01:23 PM
Q7Driver75's Avatar
Default Timing Chain?
Bank 2 on my Q7 V8 4.2 L engine is misfiring. Been told that I need to replace timing chain and cam adjusters. 160,000km on truck, 2007. Any other reasons that could cause this. Dealership quoted $6026 to fix...but only the one bank. Car runs fine while driving, but shakes in idle on occasion which forces engine error. Not buying the full story.
Old 01-15-2017, 06:54 PM
flynavy's Avatar
get a second opinion from another dealer as that doesn't sound quite right....
Old 01-17-2017, 07:30 PM
cuatrokoop's Avatar
Oil pressure (a lack of) could cause that, gives a false code.
Old 01-18-2017, 03:45 PM
Q7V8's Avatar
I replaced the oil separator with a new Audi one about 300$, and my car is running even better, like a new one... My guess was probably too much vacuum in the engine reduced the oil pressure, then both tensioner, and lower grade oil increase the problem. I hope this can help you. I also add Liqui Moly oil additive, a wonderfull product made in germany and oil pressure and tensioner are not making any noise, except 4-5 seconds after cold cold start here in montreal winter and Q7 have now 240,000km
Old 01-23-2017, 07:44 AM
Clues's Avatar
I recently had a high fuel pressure condition CEL that turned out to be caused by two broken timing chain tensioners. The broken tensioners were still intact but caused a slight misalignment in the operation of the timing chain resulting in issues with the fuel rail. The ECM, in turn, was boosting the fuel pressure to compensate.
I had absolutely no driveability issues with the Q7. The CEL was the only indication that something was wrong.
gbmarc
A4 (B8 Platform) Discussion
10-09-2017 05:12 PM
Rachid
Q7 MK 1 Discussion
05-29-2014 12:35 PM
maskinut
4.2 V8 Discussion
05-02-2007 04:41 PM
Fellert
03-15-2006 05:21 PM
Quick Reply: Timing Chain?
