Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Wheel spacers for 20" stock wheels
Old 07-22-2014, 09:30 PM
geng77's Avatar
Default Wheel spacers for 20" stock wheels
Can I see pictures of 20" stock wheels with spacers?
Old 07-23-2014, 07:00 AM
AudiWorld Expert
iconoclast's Avatar
plenty here:
https://forums.audiworld.com/q7-disc...*****-2867925/
you can do anywhere between 18-20mm front and 23-30mm rear.
make sure they're hubcentric and you purchase the extended bolts required to mount properly. use anti-seize grease on both sides of the spacers to avoid the pieces fusing together from heat or rust or any other variable.
Old 07-23-2014, 06:56 PM
geng77's Avatar
Originally Posted by iconoclast
plenty here:
thanks! i did look at that thread but couldn't find any pictures of stock height and 20" wheels with spacers. only 21 and 22's
Old 07-23-2014, 07:17 PM
AudiWorld Expert
iconoclast's Avatar
rare... not too many people put spacers on and retain stock height... it draws attention to the wheel gap and makes the vehicle look taller. (IMO)
Old 07-24-2014, 07:33 PM
geng77's Avatar
actually you have a point there. maybe it's a bad idea. heheh
Old 07-25-2014, 06:57 AM
AudiWorld Expert
iconoclast's Avatar
even though the height doesn't change the wheel gap is accentuated because now you can see exactly where the tire ends but without the spacer it is recessed into the wheel well camouflaging the actual gap.
Toxicbob
Q5/SQ5 MKI (8R) Discussion
06-29-2014 08:56 PM
dale55
09-09-2010 01:47 PM
4Ring Jelly
Audi allroad
06-14-2009 05:23 PM
JTravinski
01-23-2002 09:06 AM
Steve56g
06-25-2001 01:56 PM
Quick Reply: Wheel spacers for 20" stock wheels
