Used Q7 advice?
Used Q7 advice?
Hey guys,
I'm in the process of buying an used Q7 around 08-09. I'd like the facelifted Q7 but it is way off my budget, it costs like 10-15k more than a 09.
So having no experience whatsoever with Q7, what would you guys would recommend to look out for? Any common problems or things I should be aware of?
Thanks in advance
Thanks in advance
Make sure all the buttons and ***** work on the MMI, the usual noises while driving, but most importantly make sure all the electricals work fine so check everything like mirrors, windows, rear latch, lights ect. These cars, well all Audi's, mostly have electrical problems
thank you for your inputs. The Q7 I have my eyes on has both traction control and ABS lights on. Is this an expensive/complicated repair?
It is actually quite a good deal, it's a 09 Q7 with 18k km on the clock. The owner travelled a lot and wouldn't use the car that often. However he made all the maintenance work at the dealership. What do you guys think?
I guess if he/she doesn't intend to keep the car past two years then this is a viable option with a buyback in their future. Not sure where you are getting that there is a Mercedes engine in our VAG vehicles though. Grey
Well I have to get it to the dealer to have it inspected before I pull the trigger. Hopefully you are right and all it needs is a sensor.
The asking price is 15500$ but I dont particularly like the color (Champagne). The only reason I'm even considering this car is the very low milage. But seeing as it already has a abs problem, maybe there are some other issues hidden in the car?
I was wondering if these engines suffered from burning oil or some common issue on the engine?
