VagCom Changes and Modifications MMI-3G+...
#21
Recently completed on my vehicle:
- Current Gear Supression Disabled
- Lowered 20mm Front & 25mm Rear
- Immobilizer Active
- Disc Brake Wipe Enabled
- Hill Hold Control Enabled
- Camera Speed 20KMH
- Gauge Needle Sweep Enabled
- Lap Timer Enabled
- Oil Temperature Enabled
- Shift Suggestions / Economy Mode Active
- Fuel Door Unlock Via Driver Door Button
- Long Press Window Functionaliy Enabled
- Emergency Brake Indicator Enabled
- Brake Amplification Enabled
- Ambient Lighting Disabled
- Interior Door Handle Illumination Disabled
- Comfort Opening Front Sunroof Enabled
When I get a moment to install E-Codes, I will enable Autobahn Licht, Headlight delay reduction, Rain lighting sensitivity, & Fog Light on with high beam.
- Lap Timer Enabled
Wish i knew how to do these mods..
#24
AudiWorld Expert
it should tell you when to shift if in manual mode on the economy screen.
gear suppression is enabled from the factory. if you disable it the D & S will turn into D1, D2, D3 etc. to reflect which gear you are in and which mode.
#26
AudiWorld Expert
AudiWorld Expert
I have not had any success getting the mirrors to fold with key fob. I have tried on every Q7 I have owned and this being the newest I am going to have to call it a day and say it's just not supported by the hardware despite being coded in the software.
Enabled in all possible areas along with Diagnostic Green Screen menu. I have reached out to Ross-Tech for additional support but at this point not feeling too optimistic about it.
#28
Can you adjust the speed at which the Autobahn light comes on? I feel as if it would look like the high beams were on when it is enabled. It is the halogen light that turns on? Correct?
