Wow--my TPMS just went off
#13
AudiWorld Expert
#14
2010+ do have sensors in the wheel they go by abs/revs. pre facelift models have sensors. the easiest way to tell is look at your valve stem. if it is the standard rubber one you do not have tpms in the wheel if you have a thick aluminum valve stem then you have tpms.
no. i have tried to enable that on every Q7 starting with 2007 and it is not possible... if you search the archives or other forums under my sn you will find multiple attempts through vagcom/vcds but it just won't work.
on ROW models you can see the tire pressure and temperature... not USDM:
I thought it was some menu option I had not found previously and expected I could get back to it after doing a system pressure reset, but I have yet to be able to find that screen again after multiple attempts. I think it was a fluke software glitch/occurence that wasn't supposed to happen. I don't understand why Audi doesn't allow this display option on US Q7s with TPMS sensors.
#15
AudiWorld Expert
i do not understand either... EU A6/A8 have this available and it's very handy however nothing to be found on any of ours. i tried coding and playing around with different options and no luck. i am guessing it is part of a regional software bundle considering the hardware is the same.
even a 2010 base line touareg offers it in the mfd:
#16
Correct, on my A8 and on the Q7, I see the pressure and temp of all four wheels with a graphic display either green, amber or red for OK, warning or danger.
#18
I heard the same thing, but my TPMS light when off and I had the sensors checked in the tires and all where fine. I just borrowed a VAG and disabled the system. no more light. I went 30 years with out the light I guess I don't need it on my q7. as these vehicles get older things are going to start failing. look around the procedure to disable the system is out there..
#20
My TPMS just went off again! I guess it is working now. In this case, all four tires were about 12 lbs low. Funny that it should start working properly after being silent for seven years.
Quattrings
01-17-2016 12:42 AM
UmbroVR6
11
12-03-2015 11:44 AM
