Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Yoko Prada tires simply awesome
Old 07-16-2014, 10:08 AM
  #11
Buckwheat2088's Avatar
I have over 20k miles on OEM Continental 4x4. Still plenty of life left and no uneven wear. I can get an accurate number on the remaining tread if anyone's interested.
Old 07-16-2014, 10:31 AM
  #12
DUTCH VanAtlanta's Avatar
Originally Posted by ipo3
Update on the Yokos, 17k miles and Yokos shot!
Wow! Mine had 20k plus with about 5k tread left when I sold the car. We must have different driving habits.
Old 07-16-2014, 11:31 AM
  #13
ipo3's Avatar
I mean they were not exactly bald but tread depth was at a point where I was not confident on passing inspection, wear was even but handling was getting flaky. The root cause probably is higher heat from cornering and a bit heavy on the pedal.
Old 07-18-2014, 05:30 AM
  #14
11223's Avatar
Just did a little maintenance to my Q7.
- Yokohama Parada Spec X
275/45/20
- S-Line 5 Spoke Wheels (purchased used with TPMS) to upgrade from the 19's it came with..
- 4 Wheel Alignment
- Brake Fluid Replaced
- Hawk LTS Brake Pads All Around
So far so good, Cheers
Old 07-18-2014, 01:08 PM
  #15
Snopyro's Avatar
What's the typical cost (or cheapest source) for the Yokohama Parada Spec-X tires? I'd need (4) of them mounted and balanced. I think my buddy said he paid around $800 at America's Tire Co. Wondering if there is a lower cost vendor to buy and mount/balance the tires or is $800 about the going rate for a new set of Paradas?
Old 07-18-2014, 04:27 PM
  #16
11223's Avatar
discounttiredirect.com has them for $640 shipped plus a $25 discount currently which brings you down to $615 no tax free shipping. Can't beat that.
I paid $590 on 4th of juky weekend. . $640-$50 discount
Old 03-02-2015, 04:46 AM
  #17
will822's Avatar
Sorry to dig up an old thread but I just picked up a set of Yokohama Parada Spec X tires and wanted to know what would be the recommended tire pressure to set them. Sticker on the door I think mentions 46psi front and 49psi back but the max psi for the Yoko's says 50psi.
Thanks.
Old 03-02-2015, 05:01 AM
  #18
Thanks.
Check the inside of the door over the fuel filler.
Old 03-02-2015, 06:19 AM
  #19
will822's Avatar
This is different than the recommended max load specs on the door?
Been reading many different recommended specs online ranging from 36-42psi. Not sure which is best but currently have it set to 42psi but may think it is still slightly high?
Thanks.
Old 03-02-2015, 07:37 AM
  #20
Why not look and see for yourself?
Quick Reply: Yoko Prada tires simply awesome
