Road signs not showing up on HUD
Old 10-21-2016, 05:57 PM
youngdoc's Avatar
Default Road signs not showing up on HUD
My '17 Q7 Prestige has the nifty HUD, which is supposed to display current speed, navigation instructions, and road signs, like speed limit. I have been driving it for 2 weeks and it has shown all of those things except road signs -- so far not a single sign has appeared there. I checked the settings menu for HUD content, and all of the boxes are checked. What gives?
Old 10-21-2016, 07:56 PM
Keyser Wi's Avatar
Mine is showing all of the above ... Call your dealer?
Old 10-22-2016, 06:05 AM
RickObe's Avatar
In the Virtual Cockpit, on the data tab, scroll down to Traffic Signs. Do they show up there? Do they show up in miniature on the lower right of the VC?
The answer to this will at least narrow down whether you have a HUD problem or an overall sign recognition problem before you take it to the dealer.
Make sure nothing is obscuring the camera top center of windshield. Maybe try resetting the MMI (push Nav and Radio buttons together then push down on center button while holding the other two).
My U.S. Q7 Prestige shows the speed limit signs in both places just fine.
Old 10-22-2016, 07:26 AM
youngdoc's Avatar
I'm still new to the lingo, e.g. virtual cockpit, data tab, etc., but I can say that the only place I see road signs show up is on the lower right corner of the map when I'm displaying the map on the pop up display. Nothing is blocking the sensor at the top of the windshield as far as I can tell.
Old 10-22-2016, 07:44 AM
RickObe's Avatar
First, let me ask what country you are in. Q7's in different markets may be set up differently. Below is for a US car.
Virtual Cockpit is you electronic dashboard containing the tach, speedometer and other info. The center portion of the VC has tabs for data, nav, telephone, audio and other tabs that can pop up temporarily. You switch between tabs using the left/right arrow buttons on the left side of the steering wheel. The label of the data tab is range remaining in the gas tank.
When viewing the data tab, you can use the left scroll wheel on the steering wheel to switch among the data pages: Date/time, short term memory, long term memory, etc. If you scroll all the way to the end, you will see Traffic Signs. It will either show the traffic sign being read or something like "no traffic sign info available".
If the sign info is not showing there, then it's not working at all. If it is showing there, but not in the HUD, then you have a HUD display problem.
I'm not sure if the info displayed in the MMI's center screen is from the camera or if it's from the nav database. I've never really noticed. One way to be sure you are seeing sign recognition and not database info is to drive (slowly) by a clear and well lit school zone speed limit sign. You should see that pop up in the VC right as you pass it.
Old 10-22-2016, 12:43 PM
youngdoc's Avatar
Thanks for that, that was very informative. I knew all the machinations (scrolling and changing tabs), I just didn't know what anything was called, probably because I have just learned organically, rather than reading the manual.
I am indeed in the U.S. and I can confirm that regardless of what I drive past, the last data screen consistently reads, "no traffic sign info available," so it sounds like it is not working at all, as you suggested.
Does the car pick up traffic signs with the front camera (on the grill)? Or some other way? My front camera is working fine as far as visualization when parking.
Old 10-22-2016, 01:53 PM
LeicaNut's Avatar
The camera in the windshield picks up traffic recognition. Does your prestige have the driver assistance package? In the US, that package gives you the traffic sign recognition.
Old 04-22-2017, 12:25 PM
audifoxtoS4's Avatar
Can you manually turn it on via VAG-COM?
Old 04-22-2017, 01:14 PM
heisnuts's Avatar
That's a good point. You can have the prestige package but if you don't have the driver assistance package (adaptive cruise control and traffic jam assist) there would not be traffic sign recognition since that is only included in the driver assistance package.
DavidLA7
A7
19
07-11-2017 05:49 AM
neildaftary
Q7 MKII Discussion
22
05-24-2017 03:20 AM
dhc8guru
Q7 MKII Discussion
9
10-06-2016 12:28 PM
John Stahmann
Salt Lake City Discussion
15
03-04-2008 09:08 PM
bagodoosh
New England Discussion
01-30-2006 09:20 PM
Quick Reply: Road signs not showing up on HUD
