Tire Rotation on 10k service? - AudiWorld Forums
Old 03-19-2017, 04:01 PM   #1
PROEDGEBIKER.COM's Avatar
Default Tire Rotation on 10k service?
Just hit 9k today so its about that time to set up the appointment for the 10k hookup. Is this when most of you that have gone in for the 10k service do a tire rotation? If not, when is the recommended mileage when this rotation should occur?
PROEDGEBIKER.COM is offline   Reply With Quote
Old 03-19-2017, 04:07 PM   #2
SYMAWD's Avatar
Audi does not include tire rotation as part of the service schedule anymore.
SYMAWD is online now   Reply With Quote
Old 03-19-2017, 04:33 PM   #3
Quote:
That means that a tire rotation need to be asked for when you take the car in for service? Or I suppose you could just do it yourself at home
Mjship2001 is offline   Reply With Quote
Old 03-19-2017, 05:35 PM   #4
BigKutta's Avatar
My MB mechanic always inspects the tires to assess if a rotation is warranted. Sometimes it is, sometimes not
BigKutta is offline   Reply With Quote
Old 03-19-2017, 07:06 PM   #5
The typical tire rotation interval is every six months or 6000 to 8000 miles. Audi used to do a free tire rotation at the 5000 miles service. Get yourself a tire tread gauge and regularly monitor your tire wear. Around the above marks, see if they've worn unevenly and if so you can easily rotate them yourself. The rotation pattern for quattro is front to back on the same side, so just get a floor jack then jack up each side at once with the help of the included car jack and swap each side. Get yourself a torque wrench, too, so you can torque the wheel bolts correctly. I believe for the Q7 it's 120 lb ft.
superswiss is offline   Reply With Quote
Old 03-19-2017, 07:09 PM   #6
Bozman5000's Avatar
What's the point of wheel rotations other than to buy 4 new tires all at once instead of 2 at a time.
Bozman5000 is offline   Reply With Quote
Old 03-19-2017, 08:45 PM   #7
PeteDin206's Avatar
Quote:
You should never buy 2 tires on a quattro vehicle. You could potentially mess up the system.
PeteDin206 is online now   Reply With Quote
Old 03-20-2017, 04:22 AM   #8
Bozman5000's Avatar
Quote:
Do you have a link from Audi to confirm that? I don't remember seeing anything about that in the manual and I also find that odd as Audi doesn't even include rotating the tires as a part of the regular service maintenance.
Old 03-20-2017, 05:01 AM   #9
Quote:
I asked the service advisor for the rotation during my last 10K service, and he did it for me free of charge.
discogone is offline   Reply With Quote
Old 03-20-2017, 08:45 AM   #10
Quote:
Hoping to get that done and also take care of the can knocking sound from under the car too while it's in the air.
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
