83 URQ brake issue
Old 10-23-2016, 04:00 AM
acattard's Avatar
Default 83 URQ brake issue
Good morning everyone.I have a question regarding my 1983 URQ.Is it possible to get a hard brake pedal on the 83 URQ with the hydraulic booster (versus a vacuum booster), that is typically available on a modern Audi?I have bled the brakes several times myself and had the system bled by a reputable shop. With the engine off, I do have a hard pedal, but with the engine on, the pedal softens. I can't figure out why.I would a appreciate any suggestion(s) from anyone on the list and I thank you in advance.
Tony: 83 URQ, 2008 A3 S-line.
Old 10-23-2016, 05:34 AM
wego0002's Avatar
Hello acattard,
Your hydraulic pressure accumulator (aka the bomb) is gone. It sits on top of the pressure regulator of the hydraulic system. Replace it and you will be fine again.
Ciao
Werner
Old 10-24-2016, 05:05 AM
acattard's Avatar
Default Brake issue
Originally Posted by wego0002
Hello acattard,
Ciao
Werner
Werner,
Do you know where I could pick one up?? Thank you
ACA
Old 10-24-2016, 05:07 AM
acattard's Avatar
Werner,
ACA
Old 10-24-2016, 05:42 AM
wego0002's Avatar
No,
just google the part #
Ciao
Werner
Old 10-25-2016, 02:47 AM
acattard's Avatar
Default Brake issue
No,
Ciao
Werner
Werner, how does one go about determining if the "bomb" has indeed gone bad; presumingly it has a pin hole in it. Specifically, how does one test test the "bomb" for proper operation?? Thanks in advance.
BTW, do you happen to have the part #?. I would greatly appreciate.
ACA
Old 10-26-2016, 05:19 AM
wego0002's Avatar
The way you described it, its dead!!!
Under normal conditions you have to press the brake pedal at least 20x to get a hard feel. Resulting in no residual presure in the system. In your case it is gone right after the pump is turned off, meaning your nitrogen charge/membrane are gone.
EDEKA can help you with the part #.
Ciao
Werner
Old 10-27-2016, 04:05 AM
acattard's Avatar
Thank you very much for all your help.
Tony
Old 11-22-2016, 04:02 AM
acattard's Avatar
Good morning everyone. I have a 1983 URQ with both the sunvisor hook broken. Can anyone direct me to a source through a phone number, html site, etc. I would truly appreciated.
Tony: 83 URQ; 2008 A3 S-line.
abc27
09-21-2012 07:41 AM
Luxus Panzer
05-15-2005 08:06 PM
200Q20v
11-01-2004 04:38 PM
'81 tic-tac
09-30-2004 07:15 AM
AudiSport4000
10-07-2002 06:30 PM
Quick Reply: 83 URQ brake issue
