Bleeding brakes on 83 UR Quattro
Old 09-16-2014, 11:12 AM
acattard's Avatar
Default Bleeding brakes on 83 UR Quattro
Hi Guys,
I replaced the brake master cylinder on my 83 Ur Quattro because it was the original. Unfortunately the pedal was not what I consider to be a hard brake pedal by today's standard, after replacing the B-master cylinder I hoped I would a harder pedal. But It did not turn out that way.
I bled the master cylinder on the car, but I did not bleed all four corners. I did not think I need too. Does anyone have any advice/suggestions etc. Would be appreciated. Thank you in advance.
ACA
Old 09-27-2014, 03:55 PM
yodasfro's Avatar
Yeah you need to bleed the complete system.
Old 09-28-2014, 10:17 AM
AudisandAlfas's Avatar
Default Just Bled Mine
Most definately need to bleed them. Be careful when you turn the bleed screw. Hopefully you have rubber covers on the ends so they are clean and not corroded. After bleeding I drove the car bedded in the new pads and then rebled to get a fairly firm pedal.
sirh
A6 (C7 Platform) Discussion
09-16-2015 05:32 PM
bazookatooth
09-14-2015 08:48 AM
bazookatooth
09-12-2015 07:18 AM
RTnDL
09-07-2015 11:17 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
Quick Reply: Bleeding brakes on 83 UR Quattro
