RS 6 Discussion (C5) Discussion forum for the Audi RS 6 C5 platform
2003 RS6 Fluid Leak
Old 08-17-2016, 02:25 PM
thadco's Avatar
Default 2003 RS6 Fluid Leak
Hi All,
I have a very slow, small leak coming from the area right under the shifter. It's a light lubricant. Anyone have any idea what it could be? Is the center Torsen diff right there? I haven't jacked up the car to crawl under as yet.
TIA
Old 08-17-2016, 05:45 PM
mgmarsh39's Avatar
Center diff seal from the output shaft I bet. Having mine replaced in a couple weeks. Seems to be a weak point. I think the seal is $38 bucks.
Center diff rear seal leak-Repaired!!
Old 08-17-2016, 07:34 PM
thadco's Avatar
Thanks for the near confirmation of my suspicions.
Any idea yet what the labor cost or time is?
Old 08-18-2016, 07:05 AM
mgmarsh39's Avatar
My shop is doing it for 1hr labor.
Old 08-19-2016, 09:18 AM
thadco's Avatar
You have made my weekend! What an enormous relief. I was so worried it would cost thousands...
Old 09-21-2016, 01:11 PM
g2turbo's Avatar
Default Results?
Dropped in to see if the RS6 get's much attention here...get my 1 post in per year: 11 total
Yes, it's the 'rear AT' seal; center diff.
Curious what the actual labor in terms of hours that was charged? The process is tedius and almost requires 2 people. It's crucial to correctly align the prop shaft. I seem to have to realign them whenever someone else has "been in there".
Published flat rate times are about 3 hrs, and it will take that amount of time. That doesn't include changing the gear lube, which absolutely should be done at the same time. FWIW, i use 85-140 Amsoil in my RS6 as it's tuned and is very torque rich (as any RS6 owner knows). I can recommend specifics for the entire car (ask or PM).
Hope to see the RS6 on topic more often. Check out 'Audi RS6' on FB also.
Old 09-21-2016, 01:23 PM
mgmarsh39's Avatar
I was charged 1hr, but you're right it is a 3hr job.
Old 10-31-2016, 08:31 AM
Dr.Aronis's Avatar
(RS6.Com is the place to go for help on this)
Jon37
08-22-2015 03:58 AM
beep-beep
Audi 100 / A6 (C4 Platform)
08-16-2009 08:34 PM
SharkNardo
03-03-2008 07:55 AM
audijim113
9
05-12-2006 12:40 PM
rally
14
04-01-2005 02:30 AM
Quick Reply: 2003 RS6 Fluid Leak
