Economy mode
Economy mode
Does the RS7 go into "economy "mode with cylinder deactivation at low speeds/RPM's like the A7/S7 models? I cannot see that this happens looking at the economy gauge in the center console
Just curious
Just curious
Mine does all the time, especially if I am going a constant speed on the freeway. When the gauge turns green, that means it has deactivated.
so - I was looking at the screen that has the equipment that takes away from "economy" - found the other screen that shows the green bar that changes.
Question - when in cylinder deactivation mode, can you feel a little "lugging" vibration or noise from the engine/transmission, or is it seemless ?
I don't have an RS7 but the drive train in my A8 is virtually identical. I can't tell at all when it switches from 8 to 4 cylinders or when it switches back.
Audi has therefore developed a control logic that monitors movement of the accelerator and brake pedals and the steering wheel by the driver. If an irregular pattern is detected, cylinder deactivation may be inhibited in certain situations, for instance at a roundabout or when the car is driven hard on interurban roads. Cylinder deactivation lasting only a few seconds would tend to increase fuel consumption rather than decreasing it.
halik
12v V6 Discussion
10-21-2005 05:58 AM
strawtarget
9
07-22-2002 02:02 PM
Aggie Pilot
03-13-2002 04:50 PM
