RS 7 Transmission ?
RS 7 Transmission ?
If you are motoring along at, for instance, 70MPH and you are in 8th gear, what happens if you brake "normally" (not in full-on mashing on the pedal, simply to slow down, for example for the exit ramp)?
What I am trying to determine with certainty is if the programming of the tiptronic 8-spd makes it a virtual identical twin to the DSG's (7-spd) behavior.
In the case of the DSG, when the shift mode set to "S" -- when slowing down at a moderate clip, the transmission will downshift multiple times. Previous "automatic" transmission did not "rev match," and the DSG does it so well.
In any case, what does the tip do in an RS 7 which I assume will be the way it will operate in the 2018 S4 I (and others) will be considering.
Thanks!
Thanks!
Thanks!
Thanks!
Yes, my RS7 downshifts just like that when in S mode.
Indépendantiste
A4 (B8 Platform) Discussion
15
08-27-2010 04:11 AM
coupeboy
03-28-2006 11:27 AM
madman0
07-19-2001 03:40 PM
