Flat bottom steering wheel coding
Can anyone post the correct coding for flat bottom steering wheel.
And what component is connected to the steering wheel.
I have MFSW before this and since I installed the Flat bottom steering wheel, the steering channel gives fault code "incorrect coded module"
I'm using the following...
..."16021".
1 - Nav Installed
60 - RS4 Sport Steering Wheel
2 - Board Computer/Cruise Control Installed
1 - Rear Wiper Not Installed
Depends on your car's options.
1 - Nav Installed
Re: I'm using the following...
That's the coding that I use but still have "control module incorrectly coded". Probably its other equipment which is connected to the steering wheel is wrongly coded.
must be...
...I definitely do not have this fault code. Do you recall making any changes to other modules?
Check your phone setttings...you'll want to "inform" this module that you're not using the MF wheel.
Re: must be...
I did check everything so that no module is connected to the steering wheel. Can you post your Navigation, telephone, airbag, instruments coding? I want to compare it with mine.
I'm Vagless at the moment... but
Address 16: Steering wheel
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 16021
Shop #: WSC 06335
No fault code found.
----<ul><li><a href="http://www.navplus.us/forum/viewtopic.php?p=32457&highlight=16021#32457">s till connected-stfw</a></li></ul>
Coding: 16021
Shop #: WSC 06335
