Need help Rs4 suspension
I will be doing away with the drc suspension on my 2008 rs4
I would prefer not to lower the car or lower it very little.
Looking into doing the Bilstein sport shocks and struts kit and either keeping my stock springs or getting the H&r springs not sure which way to go the H&r only drop the car .75 front and .06 rear which is not bad since I do not want to drop the car much.
What would be the better setup ? Or recommendations
I am not opposed to a coilover kit if someone convinces me it would be much better. I do not track
Having said that, monotube high pressure gas shocks (Bilstein) are known to raise cars a slight bit. So, maybe you could use these with the H&R shocks?
AudiWorld Expert
I think most of the people who have replaced the drc are people who are more into track use. The drc is a great system and works great for street and some track. All of the aftermarket setups tend to be slightly more harsh in street use than the drc and did not provide any more performance except in extreme use.
wouldn't the shock and strut dimensions tell us that ?
No, as I said above, it is the nature of monotube high pressure gas shocks to raise the car a slight bit. At least this was the case when I used them in the past. What I don't know for a fact is if this particlar set of shocks will do the same or if the tubes are a bit shorter than stock. That's why we need someone to compare the Bilstein with the stock shocks.
audia4982,830v
09-04-2007 07:06 PM
LI-S4
12-03-2001 09:16 AM
RKA
08-23-2000 05:36 AM
