Problem with my Sirius sat radio... keeps fading in and out. Anyone else having this problem ? - AudiWorld Forums
RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Old 11-21-2006, 07:28 PM   #1
James P.'s Avatar
Default Problem with my Sirius sat radio... keeps fading in and out. Anyone else having this problem ?
I know, I know, I shouldn't even be listening to it, but I wanted to check it out...
The fading in and out is happening when I'm out on the open road with no overhead obstructions. The category column on the display shows "Linking" instead of the music type and then goes away and redisplays the category. It's really irritating and at this point I'm really glad I decided to do the 3 month demo and not pay for a year up front.
Has anyone else experienced this problem ? I'm guessing it's a bad connection or failing satellite receiver...
James P. is offline   Reply With Quote
Old 11-21-2006, 07:59 PM   #2
Default Happens to me all the time with trees, but not open sky... frankly I don't care, as the sound sucks!
sound quality sucks on sirius! I can't stand it!
RS4SPKS is offline   Reply With Quote
Old 11-21-2006, 08:11 PM   #3
James P.'s Avatar
Default Hardly any trees around here really - Denver is basically a desert...
Haven't been able to listen long enough to figure out how the sound quality is...
Old 11-21-2006, 09:37 PM   #4
Default I have it, love it, zero problems
I wouldn't own a car without it.
No signal drop out and if you're having a signal dropout, there's a problem, but don't blame Sirius.
craiglieberman is offline   Reply With Quote
Old 11-21-2006, 09:42 PM   #5
2nd
sparkhill is offline   Reply With Quote
Old 11-21-2006, 09:47 PM   #6
Default You DO know that you need to adjust....
...the sound (Bass, Treble) settings in EVERY mode of the unit? ANother words, when you switch to Sirius, you need to go adjust Bass and Treble. Same goes for CD mode. FM mode. etc.
Old 11-21-2006, 10:49 PM   #7
Default great point. I dont know how many RS4 owners acutally know this. I didnt until i heard a big
sound difference between my sources and began to troubleshoot it.
Parikh1234 is offline   Reply With Quote
Old 11-22-2006, 09:44 AM   #8
AudiWorld Expert
Reggie's Avatar
Typical - XM had lots less dropouts in all the technical reivews I read
Reggie is offline   Reply With Quote
Old 11-23-2006, 07:09 AM   #9
Default Mine does this so much that I don't even bother turning it on. It's very aggrevating because...
I want to listen and have even taken it to the dealer and they said "They all do that." WTH, its shouldn't do that. I mean mine goes out for 10 minutes at a time without any reception at all. It will say "LINKING" on the screen without any sound at all.
I've called AOA and told them about this and they said, "They stand behind their dealers diagnoses."
My car didn't come with Sirius but it did come with XM. I replaced the XM with Sirius immediately after putting the RNS-E in the car. Now I have had an XM in the car with all the same setup (as a test) and XM did not "once" drop an signal or anything. It worked flawlessly without any hiccup. So that just confirms that the antenna and all wires are properly connected. I've told AOA what all I've done to diagnose the problem and even told them that there is something possibly wrong with my actual tuner box to see if the dealer would replace it and they told me the dealer would need to keep the car for several days to diagnose it. Which I thought was kind bullsh!t because I don't have a problem with my engine or anything, I mean it's a freaking radio tuner that can easily be replaced.
I would really like to try a newer Sirius tuner in my car to find out what's wrong.
Imola Ghost is offline   Reply With Quote
Old 11-23-2006, 07:11 AM   #10
No trees or hills here in Florida either, so that can't be the problem.
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Deciding between a Golf R or an S3- Need some opinions Captain Rossness Audi A3 / S3 /RS 3 MKII 26 09-24-2015 06:34 AM
Q7 Headlight Question davidbod Q7 Discussion 2 09-14-2015 04:06 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-06-2015 06:34 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-04-2015 10:59 PM
Tags
audi, certian, fade, fading, line, open, out, problem, problems, radio, road, s5, serius, signal, sirius
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
