Startup after 2 years standstill?
Hi Guys
I need to startup the car after 2 years standstill in heated, dry garage. Had the oilcap off and if´t looks good down there. However the cams are dry from oil so I'd like to crank the engine to get oil pressure before starting it. Question is: is there a fuse or plug I could pull that will make it turn over without starting, and without drowning the cylinders i unburned fuel?
AudiWorld Expert
Hi Guys
If you can I would put oil into each cylinder through removing the spark plugs. If fact pull the plugs and let the engine rotate so there is no compression.
digimurda
20
01-17-2018 03:57 AM
hitrun222
05-15-2012 06:44 PM
MtnA4Quattro
12-29-2008 12:37 PM
mike90q
08-30-2001 03:46 AM
