RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Wynn's Direct Injection Power 3 Products
Old 05-14-2009, 04:20 AM
TexasFly's Avatar
Default Wynn's Direct Injection Power 3 Products
Does anyone know if this product line is available in the USA - I understand that it is somewhat beneficial in keeping the intake from getting sooted up from the crankcase breathing system. Regards.
Old 05-17-2009, 01:32 PM
Andyuk911's Avatar
Does this help ?
http://www.wynnsusa.com/
About GBP £15
Old 05-17-2009, 01:44 PM
Andyuk911's Avatar
DIRECT INJECTION POWER 3
Air Intake Cleaner – Spray can
DESCRIPTION
Wynn's Direct Injection Power 3 is an aerosol product developed for cleaning the air intake system of direct injection petrol engines.
PROPERTIES
 Provides immediate thorough cleaning of air intake system and inlet valves.
 Strong power jet spray to support cleaning action.
 Dissolves gum, lacquer and deposits.
 Easy to use, cleaning takes only 5 minutes, no dismantling of components necessary.
 Restores or maintains the engine performance.
 Eliminates and avoids starting problems.
 Improves acceleration properties.
APPLICATIONS
 Recommended to be used at each service interval to maintain cleanliness of the air intake manifold, inlet valves and EGR valve of direct injection petrol engines.
DIRECTIONS
 Warm up engine. Remove the air filter.
 Run engine up to 2000 rpm.
 Spray 200 ml product in short burst into the air intake manifold.
 Rpm will drop during spraying. Allow the revs to pick back up before resuming.
 If necessary, increase the throttle to avoid stalling.
 Let the engine idle for a few minutes with occasional increases in throttle, but do not exceed 3000 rpm.
 Leave the engine running for at least one minute after the last acceleration.
 Stop the engine. Put filter back in place.
TECHNICAL DATA
Appearance : clear liquid
Density at 15C : ca. 0,736 kg/dm³
Flash Point : < 21C
Propellant gas : propane
NOTE
For a perfect DISI engine cleaning, we recommend to use 2 products together:
DIP3 (Liquid – W226xx): preventative / after-treatment
Cleans the fuel system; the “wet part of the engine.
DIP3 (Aerosol – W23079): curative
Cleans the air intake manifold and the inlet valves; the “dry part” of the engine.
PACKAGING
W23079 – 12x200 ml – EN/FR/DE/ES/IT/NL/RU/EL
Do not spray on painted surfaces. In such case, immediately clean with water to prevent damage.
The data concerning properties and applications of the indicated products are offered in good faith and are based on our research and practical experiences. Due to the versatility of the application possibilities, it is impossible to mention all details and we do not assume any obligations or responsibilities resulting from this. When a new edition appears due to the technical development, the preceding data are no longer valid. The date of issue is indicated at the bottom of the page.
23079 25.09.2006
Old 05-18-2009, 12:48 PM
India Whiskey Charlie's Avatar
Originally Posted by Andyuk911
Does this help ?
I may be missing it, but I cannot find "DIRECT INJECTION POWER 3" on the US site. Perhaps, this is a EU only product?
Old 05-19-2009, 03:40 AM
OzRS4's Avatar
Hi Andy,
Thanks for the info.
With the DIP3 Aerosol, do you spray it directly into the butterfly throttle valve (by-passing the MAF)?
Old 05-20-2009, 01:57 PM
Andyuk911's Avatar
Yes.
It is easy to lift the intake and you can see the MAF ... then spray in bursts below the MAF .. keeping rpm 2,000 .... as per the directions below
ECS Tuning-Audi
Vendor Showroom
07-03-2018 08:39 PM
ECS Tuning-Audi
Vendor Showroom
11-03-2017 09:09 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
11-03-2017 09:09 AM
carid
Vendor Showroom
11-06-2015 10:35 PM
BridgeRC
10-03-2005 05:24 PM
Quick Reply: Wynn's Direct Injection Power 3 Products
