S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Help With VAG Code
Old 10-10-2015, 08:14 PM
seattlematt's Avatar
Default Help With VAG Code
17934 - Camshaft Timing Adj. Bank1 (N205)
P1526 - 001 - Short to Plus - MIL ON
Haven't had much luck searching for a solution to this code, aside from replacing my N205, what does a "short to plus" really mean? Where is the N205 on the 4.2?
Thanks
2004 A8L 4.2L
Old 10-30-2015, 11:53 AM
blueloon's Avatar
The N205 on the 4.2L V* is located at the rear of the engine, at the rear of cylinder bank 1 (left/passenger side, facing car), just below and outboard of the camshaft position sensor.
According to Ross-Tech: VAG code 17934/P1526 - Camshaft Timing Adj. Bank1 (N205): Short to Plus
Possible Symptoms
MIL On
Poor engine performance
Possible Causes
Wiring harness issue
Failed N205 adjuster (electrical)
Failed ECM
Possible Solutions
Ohm test N205 adjuster, see factory repair manual for specifications.
Inspect wiring harness to and from N205 adjuster.
Old 11-02-2015, 04:21 PM
Possible Symptoms
MIL On
Possible Causes
Failed ECM
Possible Solutions
Thanks! knowing where it is located is the hard part, I will look there, unplug/plug, clear codes, and test again.
Old 11-30-2015, 01:42 PM
Well, I identified the little bugger, unfortunately I can't seem to find a replacement anywhere that matches. The part number shows C 27 13 007 02 21 600 005 F. They replacements all seem to have the actuator parts protruding out of them, while this one came with a plastic piece and spring inserted in the hold it came from.
Old 11-30-2015, 01:43 PM
Does the picture upload and link not work on this site?
Old 11-30-2015, 02:19 PM
Here's another forum thread that talks about this solenoid Anyone ever replace n205 on 2.8 ATQ ?
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
joshA4
10-11-2015 02:43 AM
joshA4
09-29-2015 03:58 AM
Doc_A8
09-27-2015 06:02 PM
Singh15
9
09-27-2015 09:55 AM
Quick Reply: Help With VAG Code
