S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Oil pressure Indicator PLEASE HELP
Old 10-18-2016, 09:52 AM
Juxhinriza's Avatar
Default Oil pressure Indicator PLEASE HELP
I'm in desperate need of help just purchased a 05 audi S4 quattro 6 speed. oil pressure warning is going off when the vehicle hits 2000rpm and above. Have tried replacing oil level sensor and oil psi sensor. did check the pickup tube no sludge or residue seen with camera. At idle everything is perfectly fine. as soon as you hit the gas and rev it above 1500 to 2000 rpm oil psi warning goes on. it also has new oil and filter. Please help my mechanic is kind of lost and so am I.
Old 10-25-2016, 02:40 PM
Grisho's Avatar
Have you checked the codes (e.g. with a VAG-COM)? If not, best would be to check them and let me know.
Old 01-06-2018, 03:32 PM
triton6346's Avatar
Juxhinriza. My apologies for resurrecting this old thread, but what did you find out about your oil pressure problem? What ended up being the fix, assuming you found one?
ButtahBenzo
A4 (B8 Platform) Discussion
01-25-2016 12:21 PM
ttimmy2005
11-15-2012 07:39 AM
Coco-doodles
Q5/SQ5 MKI (8R) Discussion
9
07-17-2012 05:32 PM
Vanimaniac
Rocky Mountain Discussion
03-29-2009 05:11 PM
zeems
04-05-2006 04:35 AM
Quick Reply: Oil pressure Indicator PLEASE HELP
