Quick easy fix for broken glove box door
#31
elegant quick fix
i've scoured everywhere and almost bought a new glove box door. fortunately, i chanced upon this concealed hinge repair from ebay. thought i should share it with you folks.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=111424450879&globalID=EB AY-US
Waiting for mine to be shipped. will post pictures once it's repaired.
#32
eBay black hinge repair = temporary fix
Due to ease and time I decided to try the bracket on eBay to repair the broken hinge.
After about 45 days the plunger that slows the door when opening just started getting stiff again and needed to be lubed again, and then the same thing 30 days later etc.
The extra pressure from the sticking hinge plunger actually caused the steel reinforcement to bend slightly which caused the door to be out of alignment add the bent hinge caused the door to be twisted. You would need to either slam it shut or bend the whole thing into alignment (would only last a short time).
So the next step was disabling the plunger to remove the extra pressure on one side or bins hinge and that helped for a little while, but by this time the screws were not holding tightly and it would still be twisted at times.
New larger screws tightened it up, but then they didn't fit through the channel the hinge slides into when closing grrr
In still looking into a better solution, but is looking like a glove box cover or door may be the only long term solution.
#34
You can't pull these pins out, they have to be "tapped" out. Remove the glovebox and sit it on its side on the floor. Use a flathead screwdriver put up against the pin and hit it with a hammer to tap the pin out. Once the pin head comes out a bit, it's easier to get the flathead positioned behind the pinhead. It'll take a good set of hits to work the pin out.
#35
IMHO these repair hinges are not as strong as the original, and even if you remove or disable the plunger that slows the opening of the door they do flex and bend some, and the screws can losen some etc.
This then causes the door "pins" for the lock to not align 100%, and then it needs more force when closing.
You can try to chemically fasten or epoxy the hinge along with the repair, but in my case that didn't hold for the first day. Just too much pressure on it.
#36
Sounds like a great idea. I did order those Greece brackets, but I'm liking your idea. Now, I am going to see if I can even pull up the rubber covering enough to drill a hole and concealing it that way.
#37
You need to either remove the pin that attaches to the hinge, or repair or even disable it in order to stop or remove the stress on the hinge.
I found drilling a small hole in the body removed enough pressure to ease things up a bit, but that was after finding that lubricating it only worked sort term.
Not sure if that is something you should or may want to do, but I'm pretty confident if it was done prior to the hinge break it wouldn't have broke in the first place.
Matt Devo
13
06-09-2011 10:19 AM
MRSK
16
10-30-2006 06:49 AM
