2015 S4: difference between Prestige and Premium Plus?
Hi all,
From the Audi website, the only differences (aside from cost) I've been able to discern between the Prestige and the Premium Plus is that the Prestige has:
All of the other Prestige components seem add-able to Premium Plus (e.g., Technology Package and upgraded B&O audio).
Is that correct?
If so, then that would mean that the MSRP difference of $2,150 between a fully loaded Premium Plus and a Prestige is just for the adaptive Xenons! Is that right, or am I missing something?? While headlights that turn left or right in accordance with your steering wheel seem very cool, they don't seem $2,150-cool.
Thanks!
- Adaptive Xenon headlights, which are not available on Premium Plus; and
- The option to add the Driver Assist package.
Is that correct?
Thanks!
You are exactly right... You can spec a Prem+ with everything except the adaptive headlights. You would indeed be paying $2150 for the headlights, and the ability to buy the Drivers Assist package with the dynamic steering and adaptive cruise control.
I agree with you, and got a fully spec'd Prem+. Saved the $5,000.
Hi all,
Is that correct?
Thanks!
Is that correct?
Thanks!
My only complaint (need to read my owner's manual) is rain sensing wipers--do I have them or not? I see a control for the rain sensor in the MMI, but while driving in the rain the other day I waited and waited for the wipers to come on and finally turned them on manually out of fear of ending up in a ditch since I couldn't see anything! Can't figure out for the life of me how to set the wipers to auto as it doesn't appear to be an option although there is an option in the MMI to turn the rain sensor on and off.......
Auto wipers are standard across trims as well. To turn them on, move the stalk one notch above OFF position. That's it! Then there's a lever on the top side of the stalk to adjust sensitivity (4 settings I believe). I don't remember needing to set anything in the MMI. It's a great set-it-and-forget-it feature!
In addition to what others have said, if you're leasing it makes even more sense to go with an optioned up Premium Plus versus a Prestige (if you can live without the adaptive headlights) as the residual on the Prestige is 3 points lower than the Premium Plus.
That's a great point about the residual value - thanks!
