S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Mute phone mic
Old 10-15-2009, 12:06 PM
AlA4's Avatar
Default Mute phone mic
Anyone know if you can mute the bluetooth phone mic when on a call? I spend alot of time on telecons and need to be able to do this. I could not find anything in the owners manual.
Thanks,
Greg
2010 S4 Ice Silver, 6MT, Prestige, Black Napa, ADS, DA, Carbon Fiber
2005 Dodge Ram 2500 Larime 4x4 turbo desiel, 6MT
2003 Lexus GX470
Previous
2002 A4 1.8T Quattro, 5MT, sport
2000 A6 2.7T, 6MT
1994 Acura GSR 4 door 5MT
1993 Mazda MX6
1991 Eagle Talon, AWD 5MT
1988 Pontiac Grand Am SE
1984 Buick Skyhawk T-Type 5MT
1971 VW Fastback 4MT
Old 10-15-2009, 12:51 PM
derazmus's Avatar
While on the phone screen in the MMI, hit the "Setup" button. I think it's in there. Were you looking in the owner's manual or the separate MMI user's manual? It may be in the latter.
Old 10-15-2009, 01:17 PM
tgdA4's Avatar
It may not be possible. I've looked around the MMI for this option too. Perhaps you can mute the phone itself? (not ideal, I know)
Old 10-15-2009, 03:11 PM
NWS4Guy's Avatar
That should work, since the phone just sees the car like any other bluetooth headpiece - when you mute the phone it mutes all bluetooth output too(or it's supposed to).
Old 10-15-2009, 06:01 PM
UABigBird's Avatar
Default Tel -> Options
When you have the phone active in a call so you see the MMI change to the phone screen, hit the corner key that says options, then keep it on that screen. You can scroll through the 3 options there, and choose mute with the nav wheel and click it.
Once I type it out it sounds like a lot, but it's really easy. I think there's also a way to mute with the scroll wheel / mode button on the left of the steering wheel, but I just use the nav wheel.
Old 10-16-2009, 06:28 AM
derazmus's Avatar
One thing to watch out for: I think the MMI Mute option stays where you set it. If you turn mute on and then hang up, it will still be on mute the next call you take. This drove me nuts when I took delivery of the car last Friday and found I couldn't answer a call. Later on in my garage testing it, I eventually found the Mute option and turned it off.
Would have been nice if Mute was on one of the four corners of the Telephone screen or if there was some obvious indication on the phone screen that you are Muted.
Old 10-16-2009, 10:34 AM
AlA4's Avatar
Thanks for the info and the warning. It works as described above.
Greg
Old 07-21-2014, 10:56 AM
pm_wizard's Avatar
I had that problem, and it drove me nuts. Every call I made or that came in had the mic muted. I finally figured it out (I think). I agree it could be a little bit more obvious and simple to use!
John
S6Express
A6 (C7 Platform) Discussion
01-29-2022 04:31 AM
lmariorod
10-26-2017 11:39 AM
mickster
TT (Mk3) Discussion
27
05-20-2016 07:33 AM
Quick Reply: Mute phone mic
