Anyone have clunking noise in their front suspension?
#61
The S4 cars have a known issue and there is a TSB addressing it. I don't believe anyone has identified the issue in the A4 cars with the Sport suspension...
#62
Note that if a tech only does a visual inspection and yanking, pulling or pressing of the engine, chassis and suspension components, it may not reveal that a bolt is not tightened to factory specification. That was what happened in my case until he put a torque wrench on all the bolts and found the one engine mount bolt that was not tightened to factory spec. Low speed clunking problem solved. No TSB, just careful, methodical checking for spec with the proper tool.
#63
Thanks,
aty
#64
Does anyone have any other link to Audi S4's TSB? This is what I found and it doesn't have the one that states the clunking noise that we hear in our cars.
2012 Audi S4 Technical Service Bulletins (TSB)
#65
See the attached image. I used to get this problem pulling into my alleyway. They replaced some guide links in the bushings and loosened, let the motor sit, and then re-torqued it in.
Thanks!
Thanks!
#66
Thanks again.
#67
Resolved
I got my car back (they tightened everything back to spec and blamed it on my replacement brake pads - hawk performance ceremics which they installed for me). Suggested I should go back to stock and see if the noise comes back.
Anyway the noise disappeared for about a month and now I am hearing signs of it again. I saw a few posts about a TSB # to loosen the engine mounts... did anyone share this TSB #??? Are you still having the problem?
#68
I am having this exact same problem on my 2010 A4 Avant. Whenever the body weight of the car shifts front to back I hear the clunking in the right front of the car. Doesn't matter the temperature. It does it the most at low speeds and turning, as others have described.
#69
#70
My 2011 S4 has recently developed a clunk as well. Seems to be coming from the drivers side although that's not clear. Does not seem to be temperature related - I get a clunk when engaging the clutch and the car starts moving and then a slightly different clunk when first hitting the brakes.
I checked the Alu Kreuz but all the bolts are tight - going to bring it into the dealership for a look. Unrelated but I noticed a bit of fluid on either side of the driveshaft tunnel (on the chassis). I wasn't sure but it looked like oil making me wonder if a seal is leaking, so now I have 2 reasons to have the dealer look at it. This will be the first time having it looked at while under the dealer sold Fidelity aftermarket warranty. Will post back next week once I get an updated.
