S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Bang and Olufsen (B&O) Subwoofer / Amplifier Add-On DIY
Old 09-14-2014, 10:06 AM
  #51
JamesCoyne's Avatar
Originally Posted by Bobby Kinstle
Yes, wire the coils in series for the B&O, in parallel with a 2ohm external amp.
How would you go about wiring this just to the OEM amp for now?
Old 09-14-2014, 02:12 PM
  #52
m444's Avatar
The Kicker 2013 CompD Subwoofer manual shows the connection diagram for wiring the two 4 ohm voice coils in series to get 8 ohms: http://www.kicker.com/sites/default/...0Rev%20C_0.pdf
Old 09-14-2014, 09:41 PM
  #53
JamesCoyne's Avatar
Finally did it today, dropped in the Kicker CompD 40CWD104 CompD Series 10 inch Subwoofer Dual 4 Ohm sub and it sounds amazing. Wired as m444 and others said as 8 ohm. 89 bucks and about 50 bucks worth of dynamat(not in picture) and the B&O sounds levels better than before. Have a bit of rattle I think on the B&O grill that goes over the sub, any ideas how to fix that?
Cheers
Kicker 40CWD104 CompD Series 10 inch Subwoofer Dual 4 Ohm
Old 09-15-2014, 05:08 PM
  #54
Cooper993's Avatar
Can you post a picture of how low it hangs into the trunk? I've been wanting to upgrade the sub but don't want to lose the space the JL takes up
Old 09-16-2014, 06:18 AM
  #55
AudiWorld Uber User
Bobby Kinstle's Avatar
I was going t ask the same thing as my Pioneer sub takes up quite a chunk of trunk space.
Old 09-16-2014, 08:28 PM
  #56
m444's Avatar
Here: https://www.audiworld.com/forums/s4-.../#post24059923
Old 09-17-2014, 04:15 AM
  #57
Cooper993's Avatar
I'm familiar with that thread but that's a different kicker model. Are they the same dimensions?
Old 09-17-2014, 06:56 AM
  #58
JamesCoyne's Avatar
I apologize for the quality of this pic, I took it at night but this is how low it hangs. I was in a rush towards the end of the installation so the wiring isn't cleaned up yet. After a few days it has been sounding better and better and the rattle went away. Wired for 8 Ohms. Obviously it will sound different based on how well a song is mastered and the type of song, but I find myself having to turn down the bass on a lot of songs because it is too much(a good problem to have ha!). I am a huge audiophile and couldn't be happier with this upgrade.
I contacted an ebay seller to custom make a spacer and it turned out great. Was 18 bucks cut and shipped within a day. Contact carforce1@att.net and he will hook you up. 1.25" thick and Outside dimension of 9.625" and the inside dimension of 9.125". Didn't need to trim anything and it all fit perfectly.
Highly recommended.
Old 09-17-2014, 08:02 AM
  #59
Cooper993's Avatar
Thanks for that picture. It looks like that sub hangs down about 4-5 inches. Is that correct?
Also, since I am not familiar how high the mounting ring can be, is there more room to raise the sub even higher or is it at its limit?
Old 09-17-2014, 04:56 PM
  #60
m444's Avatar
It is just an older model of the COMP (10" 8 ohm). The basket should be the same size.
The ring I used was 1.5" thick, which is pushing the limit for a flat ring. It would be better to have an angled ring with 1/2" difference between the sides for clearance to the speaker grille. I had to trim the underside of the grille.
Quick Reply: Bang and Olufsen (B&O) Subwoofer / Amplifier Add-On DIY
