Bang and Olufsen (B&O) Subwoofer / Amplifier Add-On DIY
#51
#52
The Kicker 2013 CompD Subwoofer manual shows the connection diagram for wiring the two 4 ohm voice coils in series to get 8 ohms: http://www.kicker.com/sites/default/...0Rev%20C_0.pdf
#53
Finally did it today, dropped in the Kicker CompD 40CWD104 CompD Series 10 inch Subwoofer Dual 4 Ohm sub and it sounds amazing. Wired as m444 and others said as 8 ohm. 89 bucks and about 50 bucks worth of dynamat(not in picture) and the B&O sounds levels better than before. Have a bit of rattle I think on the B&O grill that goes over the sub, any ideas how to fix that?
Cheers
Kicker 40CWD104 CompD Series 10 inch Subwoofer Dual 4 Ohm
Cheers
#55
AudiWorld Uber User
I was going t ask the same thing as my Pioneer sub takes up quite a chunk of trunk space.
#56
#58
I contacted an ebay seller to custom make a spacer and it turned out great. Was 18 bucks cut and shipped within a day. Contact carforce1@att.net and he will hook you up. 1.25" thick and Outside dimension of 9.625" and the inside dimension of 9.125". Didn't need to trim anything and it all fit perfectly.
Highly recommended.
#59
Thanks for that picture. It looks like that sub hangs down about 4-5 inches. Is that correct?
Also, since I am not familiar how high the mounting ring can be, is there more room to raise the sub even higher or is it at its limit?
#60
The ring I used was 1.5" thick, which is pushing the limit for a flat ring. It would be better to have an angled ring with 1/2" difference between the sides for clearance to the speaker grille. I had to trim the underside of the grille.
