S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Bang and Olufsen (B&O) Subwoofer / Amplifier Add-On DIY
Old 09-17-2014, 05:39 PM
  #61
JamesCoyne's Avatar
Originally Posted by Cooper993
Thanks for that picture. It looks like that sub hangs down about 4-5 inches. Is that correct?
Also, since I am not familiar how high the mounting ring can be, is there more room to raise the sub even higher or is it at its limit?
It was right on the edge of the B&O grills that house the tweeters and sub so I wouldn't do anything different from those dimensions I put.
chihjenchi (07-11-2019)
Old 09-21-2014, 11:16 AM
  #62
m444's Avatar
It hangs down less than 3", with the 1.5" ring, which is about the maximum ring thickness one could use.
Old 10-21-2014, 06:16 AM
  #63
typ44q's Avatar
Would you say the ideal spacer thickness would be 1"-1.5" angled?
I am really debating between the efficient Pioneer sub with stock amp vs. doing a shallow mount 4 ohm sub that would require an additional amp. More money and work but with a spacer the shallow mount sub would only stick down about 1.5" depending on the sub.
Old 10-22-2014, 05:49 AM
  #64
AudiWorld Uber User
Bobby Kinstle's Avatar
Offhand I'd say whatever spacer you can find easily is the best. The depth of the pioneer sub has only once been a problem for me, and I was able to rearrange things around it ok, so not much of a problem.
Old 10-22-2014, 05:59 AM
  #65
typ44q's Avatar
I was going to ask a friend of mine to custom make one so I figured I would go with whatever was ideal to maximize trunk space.
Old 10-23-2014, 07:34 PM
  #66
m444's Avatar
Angled spacer ring would be best, with front to back angle range around 0.5" to 1.0" & should be less than 1.5" tall (1.25" is good), at the highest point. Inside diameter around 9.125".
Old 10-24-2014, 06:16 AM
  #67
typ44q's Avatar
Thanks!
Old 12-04-2014, 06:43 PM
  #68
Dav4's Avatar
Hey there,
What is that black/purple wire that you spliced into? What does it lead to?
Thanks.
Old 12-04-2014, 09:42 PM
  #69
AudiWorld Uber User
Originally Posted by Dav4
Hey there,
Thanks.
Dunno, the subwoofer cable is green/blue and yellow
Old 12-05-2014, 05:52 AM
  #70
Dav4's Avatar
Meant the wire from the fuse box used as a remote turn on.
Just wondering what that wire is from.
Followed this write up months ago to install a box in my car. Worked great!! Now my car is back in for service for the third time where I'm getting codes and they can't figure out where it's coming from. They called in an Audi Canada service tech to come see the car. I'm just a little worried they might find what is spliced into and try to put it on me. I'm confident it has nothing to do with me, but can't help but worry until I get word from them.
They even called me and asked if I have ever chipped the car.
They're stumped
Quick Reply: Bang and Olufsen (B&O) Subwoofer / Amplifier Add-On DIY
