Big Brake Kit for 2014 S4!
RS Brakes for 2014 S4! Stock brakes are not good enough for track events!
Hey guys,
I need some advise. I have attended a few HPDE track events in the past and as much as I like my S4 the stock brakes are simply not made for the kind of driving.
Currently I am thinking about upgrading my front brakes but there are so many choices out there (StopTech, Revo, K-Sport and Audi RS brakes) so I'm looking for some advise from my fellow Audi guys...
Thanks for your feedback, it is much appreciated!
I used Stoptech's on my Subaru STi. Usually the brake pads and fluid make more of a difference than more pistons on the caliper. There are many cars with standard brakes that have no issues with HPDE.
Unless money is no object I would get a set of xp 10's (front) and xp 8's for the rear. It will change your mind.
Hey Guys,
I know I have been asking this a while ago but currently I am thinking about RS Big Brake Kits sold by ECS Tuning. Either the RS Stage 3 kit with the 365x34 with the wave rotors or the the Stage 3 kit 365x38 with the Porsche calipers.
I wanted to hear some feedback from people already using their brake kits. Usually I rely on customer reviews but there aren't any out there.
It looks like you are getting more for your money versus Brembo, StopTech etc. but I wanted to hear from Audi guys that are already using those brakes.
Thank you!
Thank you!
What kind of cooling do you have?
Are you locking them up or engaging the ABS or are they just not holding up after hard laps and fading hard?
What kind of pads are you running? Bigger brakes without adequate cooling is just going to buy you some more laps until you run into the same problem.
Second question is what kind of fluid and are you fading due to boiling the fluid?
You swapping fluid in the calipers before every event?
The issue I had last time on the track that my brakes started to fade after hard laps and on day two I had pretty bad vibrations felt on the steering wheel and brake pedal.
Audi dealer replaced my pads and rotors. Apparently the pads started to eat into the rotors at least that's what they stated. Everything on my car is stock however I did replace the brake fluid with Motul600 but I did not have it flushed before the last track event.
I think if I want to continue doing track events there is no way around bigger brakes.
Hey Guys,
Thank you!
Thank you!
I recommend going Brembo or Stoptech. Even Audi RS brakes are not the best for road course use (I've seen them fail on a TT-RS even with endurance pads and fluid, the only caveat being he was on R compound tires).
Eric, thanks for your reply.
More weight, more energy to shed, creates more heat.
Now me personally if you are getting a full day out of stock equipment I would not be complaining.
Totally stock, even pads? Those pads are not meant to be tracked.
So a few things:
Do you do a cool down lap when your done?
Do you not use the brakes at all once exiting the track? When I leave the track after a cool down lap I never touch the brakes, ever. Use the trans to get as slow and I can, and just let the clutch out in 1st after turning the car off to stop it. Never set the e-brake
Bigger brakes will help, but thats only because you are increasing the surface area so they take longer to heat up.
Cooling is key because even if you go with a larger rotor that helps you can still boil the fluid in the caliper.
I ran something similar to this on my Corvette:
On your calipers you should bleed just the caliper itself after every event. Also remember high temp fluid has a much higher ability to retain water so it needs to be changed more often, every 3-4 months, or every 3-4 events.
Plus a much more aggressive pad. You should put on track specific pads at the track, then street pads. None of the "street/track" pads are worth much if you want to get good consistent braking performance.
Then once you do all that I would look at boot protectors, we used to melt all the rubber for the A-arms and tie rods because of the heat from the brakes.
ckeck
09-08-2008 06:27 PM
Yancy
06-03-2004 09:04 PM
