S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Temperature gauge showing hot
Old 10-27-2013, 05:14 AM
cobalt21's Avatar
Default Temperature gauge showing hot
2011 s4 with 67,000 miles suddenly showing engine running hot. After pulling over the temperature returns to normal. Coolant level is normal and fans are running. Temperature goes up when accelerating and goes down quickly when coasting. Both fans running when we got home and engine is not hot at all.
It is a 45 mile commute and normally only 1 fan is running. Hoses are not hot
and you can put your hand on the engine. Could it be a sensor? Also the warning light came on only once and the the oil display showed up all of a sudden and showed normal. Any thoughts on what it could be. I believe we had the thermostat and pump done under recall years ago. Once again the engine was not hot.
Old 10-27-2013, 06:11 AM
RobC's Avatar
If your coolant level is normal, then it's likely the thermostat.
csouther
Q7 MK 1 Discussion
10-08-2018 08:57 AM
TSTARKS77
57
10-10-2012 01:35 PM
milan2k12
04-17-2012 05:25 PM
audiTLC
02-15-2009 07:43 PM
cedricl
24
12-18-2006 04:54 PM
Quick Reply: Temperature gauge showing hot
