DIY: Hardwired Radar Detector Install
#11
I don't have the stealth display - getting it wired behind the instrument cluster might be a tricky affair.
What about the ashtray? Perhaps it can be hidden under the sliding cover.
I also saw this picture over in the Audizine forums:
Thread: http://www.audizine.com/forum/showthread.php?t=337154
Please make sure to post some pics if you install the stealth display!
I considered the ash tray location, but it'd be a remove, modify and re-install scenario. This is completely removable without damage.
#12
great instructions
I followed your tutorial exactly and the install went very smoothly! Its almost amazing how ideal the bone tool (also known as a bone folder) is for the job. I found one at the local hardware store that has an extensive paper/printing section.
There is another V1 install tutorial here, https://www.audiworld.com/forums/sho....php?t=2720748, that mentions using a 7.5 A fuse. Good additional thing to mention as the fuse circuit tap I used came with a few options and I could have easily used the 5 A thinking it was enough, but another poster mentioned a blown V1 after doing that.
I'm a tad bit concerned right now that I have either a placement issue (did I go too high up?) or the car has some wacky interference from the lane-assist sonar as I took the car out and had the V1 on and was seeing way more chatter than I'm used to around town. I'll play with the lane-assist and do a test with a much lower placement (using the cigarette-lighter power) and see if it behaves differently.
#13
I just started another thread with my version of the stealth display install. The wiring was easy.
#14
Glad to hear everything worked out!
The V1 actually uses a 1 AMP in-line fuse: http://www.valentine1.com/store/defa...gory=partsdept
So you should be fine using something pretty small. I think the smallest that came with my tap was 2 AMP.
As to the lane-assist - I've heard people mention this. Maybe these links will have something useful:
http://www.eabjr.com/Side-Assist-and...r-Detector.php
Reprogramming the V1:
http://www.valentine1.com/Lab/MikesLabRpt3.asp
#15
I have installed my radar detector with the add-a-fuse harness but I'm having trouble finding a switched circuit. Even the radio/nav and the instrument cluster circuits don't kill the power when ignition is off?? I've done this with other cars and never had a problem...what am I missing??
#16
Steve
#18
Got a PM asking me which fuse location I used:
I used the empty fuse position #2.
According to the sticker inside the fuse panel, #1 is used for dynamic steering, but the fuse location was empty in my car - so fitting into position #2 wasn't a tight fit.
Anyway - hope that helps!
#19
Nice write up. I mounted mine on the passenger visor but otherwise installed the same way. I mounted the remote display at the bottom of the center console using 3M Dual Lock. It is not a big deal to glance at it or mute it when an alert sounds.
