Does Vagcom affect mfr's warranty?
Hello, I have been reading up on Vag-com and planning to buy Ross-Tech VCDS in the near future. My question is: Does changing the settings via Vag-com affect the mfg warranty? Will Audi dealer flag it as TD1 or give me trouble if I change some settings (ie. video in motion, LED blinker on, windows up/down remote, etc.)? Appreciate your advice!
NO. VAGCOM either activates or deactivates what your vehicle already has installed. Make sure you visit and follow the detailed instructions on " audienthusiasts.com " and donate if you do use that website.
Good Luck.
Good Luck.
One caveat: there are coding changes that can screw up the operation of your car which would not be covered by the warranty. If you are not an expert and stick to the Vag modifications that others have fully tested and proven to work without issues, you will have no problem with the warranty.
One other FYI..While it doesn't usually occur, if you have your MMI version updated (or reloaded for some service reason) there's a possibility you will lose some mods back to the default. It's happened to me just once. Not a big deal as you can always redo any that get "erased".
Also, it's not a bad idea to run a full scan before you take the car in for service. If there are any fault codes, even though they should run their own scan, you can point them out to the service tech. Can't hurt - I had one they missed that helped result in a warranty repair.
Have Fun!
If I do point out any fault codes to the dealer, this means it's perfectly okay to inform the dealer that I use Vag-com, right? In other words, the dealers don't mind that we use Vag-com to change settings and access the hidden menu?
As to the hidden menu, stay away from the "Bootloader" option as it will likely render your MMI unusable.
I've been using VCDS and been making mods for 14 years, with four Audis, four different service depts. in two states and never had a problem when my car was in for dealer service.
