S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Drive Select: feature or software bug?
Old 01-04-2014, 02:04 PM
  #11
rdef's Avatar
There is huge difference between Dynamic/S and Dynamic/D. Shift points and throttle sensitivity are night and day.
Old 01-04-2014, 02:47 PM
  #12
AudiWorld Uber User
Bobby Kinstle's Avatar
There appears to be desired shift and cruise RPM points in the D/S mode and they don't seem to care what ADS mode you are in. I noticed that in Auto Mode, most things tend to be more towards comfort when in D mode and more towards Dynamic in S mode. Even the soundaktor switches on (it does not in comfort mode S)
Old 01-05-2014, 12:54 PM
  #13
sworksone's Avatar
I just went for a little test drive. I put the car in dynamic and brought it up to a constant speed on the highway. I then shifted from S to D, and it shifted up two gears in pretty rapid fashion. I then shifted back and forth between S and D, and every time, it shifted one gear lower and higher respectively. Unless the engine/throttle is switching out of dynamic (while set in dynamic) when shifting from S to D, then dynamic and sport are not the same?
Old 04-29-2014, 07:23 PM
  #14
Thes6isWicked's Avatar
Did this ever get figured out - are D and S the same ad far as engine and tranny shift mapping?
Old 04-29-2014, 08:21 PM
  #15
PhilNotHill's Avatar
I am assuming this is a moot issue for those of us with manual transmissions?
I use Individual Mode where the engine is Dynamic and the suspension is Comfort.
Best.
Old 04-30-2014, 05:51 AM
  #16
snagitseven's Avatar
One more time. For throttle and gear mapping only:
- D on the shift lever is the same as Comfort or Auto in the MMI ADS settings and will override the Dynamic engine/transmission MMI setting.
- S on the shift lever is the same as Dynamic in the MMI ADS setting and will override the Comfort or Auto engine/transmission MMI setting.
- Other MMI ADS settings, i.e. steering, suspension, etc., are not affected by the shift lever.
All of the above is well documented.
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
N'Syncro
33
02-16-2020 03:12 PM
Cadx6
TT (Mk2) Discussion
24
12-15-2016 05:37 PM
Dr Chill
S6 (C7 Platform) Discussion
11-05-2015 09:25 PM
bebopdeluxe
A6 (C7 Platform) Discussion
09-05-2015 04:11 PM
Quick Reply: Drive Select: feature or software bug?
