S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Reliability issue Thermostats?
Old 08-23-2014, 07:12 AM
jyges's Avatar
Default Reliability issue Thermostats?
On the other. Audi board there are multiple posts of thermostat failures .Is it a real problem & what is cost to replace out of warranty.also do overheats due to stuck closed thermostats cause major engine damage as they due on my E39 BMW (1997-2003 ) 6 cylinders.
Old 08-23-2014, 07:39 AM
Banned
DrGP's Avatar
They have been problematic. There was a recall and all the bad T Stats as well as water pumps should have been replaced under warranty. BUT, there still are occasional reports of 2nd T stat failures. The problem is that the Supercharger needs to be removed to get to the T stat. Don't think engine damage is common as long as you don't continue to drive and overheat the engine. The T stats seem to fail in the closed position
Old 08-25-2014, 10:53 AM
Timmay's Avatar
Doesn't the T stat simply monitor the temps? I can't imagine it actually being the root cause of engine failure. As far as I know it's not regulating anything. I haven't had this issue with my new S4 of course but I did experience it with my '06 A3. Due to the transverse mounted engine it takes a crap load of time and labor just to get at it = $$$
Old 08-25-2014, 10:58 AM
gforaker's Avatar
An engine thermostat regulates the flow of water through the engine and therefor the engine temperature. You are thinking temperature sensor, not thermostat.
Old 08-25-2014, 11:02 AM
Timmay's Avatar
Ah you're right, thanks!
Tyron Naidoo
09-12-2018 03:06 PM
BiturboA6
05-12-2011 05:00 AM
BiturboA6
A6 (C7 Platform) Discussion
05-11-2011 07:47 AM
Tom Westover
Quattro: Turbo / Ur / Sport
06-19-2006 11:05 AM
Jerry D
Canadian Discussion
16
09-21-2005 01:14 AM
Quick Reply: Reliability issue Thermostats?
