How much oil does your S4 use?
#92
AudiWorld Uber User
No, I'm not letting you off that easily. My suggestion is to follow the manufacturer suggested break in, which not coincidentally is basically the same as suggested by every auto manufacturer. Therefore this is the "normal" accepted behavior. You don't have to prove why normal is better to convince people to be normal. They do it naturally. Now if I said that walking on your hands wearing clown makeup was better for your circulation and cleanly ignored issues like wear on your wrists or pressure on your eyeballs, that would be an example of claiming a behavior, which is clearly abnormal, is better based on one aspect of a complex system and the "normal" group would indeed require significant evidence to convince them to change their ways.
You claimed you had evidence. Present it.
#93
Banned
#94
For as long as you and I have been on theses forums, Do you recall any posts about someone complaining about oil consumption issues and they are sorry that they used a more agressive break in thechnique? I haven't. Have you seen any post from owners who used a more agessive technique reporting little or no oil consuption. I have. I've seen owners using the easy technique also reporting little or no oil consumption as well. Have you seen owners that did the Easy break in complaining of oil consumption issues. I've seen quite a few. I really am not intersted in getting into a pissing contest with you. If you want to do the easy technique or advocte it, be my guest. I don't have to prove anything. The technique works and those that have tried it are happy. Hopefully we are dealing with intelligent adults who will all be able to to makeup their own minds as to which technique they are comfortable with.
#95
Banned
Have you gone onto the Motoman site? They provide some pretty convincing evidence. Yes they are using motorcycles not car engines. But the principles are the same for any internal combustion engine. And you are right,they are opinions. But opinions based on empircal evidence.
#96
3 more words on break- in:
NO SYNTHETIC OIL !!
Use Valvoline, Halvoline, or similar 10 w 40 Petroleum Car Oil for at least
2 full days of hard racing or 1,500 miles of street riding / driving.
After that use your favorite brand of oil.
And keep in mind, the critical break-in period is the first 20 miles. And according to Motoman, you are suppose to change the oil and filter after the first 20 miles following his method.
I will like to know how many of the empirical evidence you suggest to have had followed this exact method of breaking in a new engine within the first 20 miles of its life.
#97
I have 14K on a 2014 S4 and just received a low-oil (add a quart) message.
I bought the car 5 months ago with 12K miles and its been to dealer for check-up service.
If the car is consuming oil now, is there any way at this point to know if it's from a weak break-in or otherwise? Will it continue to do so? I never smell it burning nor see any evidence of drippings...
#99
2011 S4, have to put in a liter every 8,000km or so. Typically now just do a full oil change since the recommended 15,000km oil change interval is simply ridiculous. According to the dealership, "it's normal" to go through a liter of oil in 7 or 8,000km (not miles). I bought the car when it was just shy of a year old though so not sure how it was broken in.
meck s4
13
06-03-2007 08:12 AM
tonybah
20
03-07-2005 06:11 AM
2001, 2004, 2011, aggressive, audi, b5, b6, b7, break, consumption, liters, oil, recommendation, s4, use
