Keep that harness safe. Meet the AWE Tuning Wiring Harness Relocation Kit for B8 S4s.
Audiworld Basic Sponsor
Introducing a simple yet effectively engineered piece, designed to save your vehicle’s wiring harness. You need to read this.
Once upon a time…
...when we installed the SPC Adjustable Control Arms to our Samoa Orange Audi S5, there was no question that they performed as intended: Our camber measurements were back in an acceptable range that would improve both handling and tire wear.
Then…
Something scary happened. When the front suspension compressed with the SPC arms installed, the upper control arms came into contact with the wiring harnesses that are routed through both front fender wells. Wear ensued.
But why does this matter, AWE Tuning?
Great question. In modern vehicles, the wiring harness is like the human nervous system; it transports both power and signals to and from various systems and components, and is hypercritical to maintaining overall vehicle function and control. Over time, repeated contact of the suspension with the wiring harness will compromise the integrity of the wiring itself, which will inevitably lead to expensive repairs further down the road. To combat this critical issue our engineers devised the AWE Tuning Wiring Harness Relocation Kit. CNC’d out of 6061 billet aluminum, the kit contains two simple brackets that relocate your B8 S4's wiring harness out of the danger zone, and keep systems in the clear.
How might one attain this level of billet bracketry?
The kit is available as an affordable package with SPC Adjustable control arms, or solo for those who already own the control arms.
Click here to find out more about how AWE Tuning can help keep you sane and your B8 S4's harness safe.
Once upon a time…
Then…
Meet the AWE Tuning Subframe Alignment Tool, designed to center your subframe and keep your alignment process headache-free when installing SPC Adjustable control arms on B8 and B8.5 Audi vehicles.
More info, including pricing and package options, can be found, HERE.
Tis' the season for sticky rubber. Bring on the wide wheels and aggressive alignments.
We specifically designed the AWE Tuning Wiring Harness Relocation Kit to prevent catastrophic damage to the factory wiring harness inside the front wheel wells caused by suspension components contacting the wiring harness at full compression. If you are running SPC control arms to conquer your camber, we strongly urge you to consider our solution.
Each billet 6061 aluminum bracket is made in-house at AWE for you. If you have any questions, ask me!
Josh/AWE
A4 (B8 Platform) Discussion
05-14-2015 12:36 PM
Josh/AWE
05-14-2015 12:36 PM
Josh/AWE
05-06-2013 09:20 AM
Josh/AWE
04-15-2013 11:32 AM
Josh/AWE
S4 (B8 Platform) Discussion
04-15-2013 11:31 AM
