S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Larger crank pulley on B8 S4.
Old 01-12-2017, 03:52 AM
cookie28b's Avatar
Default Larger crank pulley on B8 S4.
Could someone clarify an idea I have.
My B8 S4 has a Tuning box installed. I am pretty happy with the results.
What I am thinking is if I install a larger crank pulley (JHM for example) and leave the bypass valve set at the factory level, will the maximum boost come in earlier in the rev range. My thoughts are with the factory bypass valve at factory level there shouldn't be an increase in boost but the maximum boost will be attained earlier in the rev range.
Is this a feasible idea or am I talking rubbish.
Old 01-19-2017, 04:00 PM
bhvrdr's Avatar
You may get a bit more boost down low. If you keep your tuning box hooked up and put it on its max settings you'll get even more boost. If you dont run the tuning box then by mid rpms your car will still have the same boost as stock, so 1/4 mile times wouldnt improve much. With the tuner box installed (assuming its working right) you'll see at least stage 1 levels of performance which is nice.
Mike
Old 02-19-2017, 05:57 AM
maty360414's Avatar
yeahhh get the 179mm JHM Crank Pulley
Old 03-06-2017, 05:34 PM
Kustomimports's Avatar
Or you could go with a kustomimports crank pulley. Better options then jhm. there are a few different sizes to choose from.
I8ABUG
04-16-2006 03:35 PM
TwisTTer
15
12-02-2004 01:47 PM
dalix
48
07-06-2004 08:49 AM
jae shin
04-05-2004 01:46 PM
Sam Higashi
Performance and Tuning
10-29-2000 05:25 PM
Quick Reply: Larger crank pulley on B8 S4.
