Manual Transmission Issues w/the 2010 Model
I have seen in other Audi Forums there seems to be a design issue with the manual transmission on the S4 (B8) 2010 Model. Here's what I am running into. About a year ago the car was having trouble starting. It felt like you had to push the clutch to the floor and sometimes it would start. The Audi dealer said the pressure plate needed replacement and recommended the clutch be done at the same time. It was $3,200+ tax. I only had 43k or 47k miles on the car. I am light driver and have driven manual Audis, VWs and Volvos and never replaced a clutch with such low miles. 14 months later the same problem came back. The service manager explained that he believed it might be a design issue with the hydraulic self adjusting clutch. Audi only would warranty the prior replacement if it was 12 months / 12k miles. It had been 14 months and something like only 7k or 9k miles since the last replacement. The Dealer is paying for the replacement as I've been a customer for 17+ years, etc. They are currently taking apart the transmission and looking at everything. This car is in MINT condition. My question is I've never had a car that needed three clutches with only 55k miles. Should I sell this and run when I get back? Given there seem to be others with the same problem in other forums I am wondering if this is a class action suit or a recall about to come. Like the water pumps were. Any ideas or suggestions appreciated. Thanks.
Banned
I had 3 B8 S4s all with MTs including a 2010. The problem is not with your clutch assembly. The problem is with the clutch pedal position switch. Fairly common problem. Current car has 70k miles with what I believe is the original clutch, but bought the car used. . Its sad when the service techs cannot diagnose a problem correctly.
At one point a friend who looked at it found a code with his Rosstech scanner that he says needed resetting, but no one else including the audi garage its sitting at today knows anything about a resent procedure. I haven't been able to get the car to the person who claims there's a code and doesn't recall where it was. In support of the idea its a reset is that the problem happens immediately after replacing the slave cylinder
When you do press so hard you bust the slave, it cures the starting problem, but you have a weeks to months before the slave lets go entirely and you're stranded, and the clutch behaves erratically in the interim.
Most frustrating is that there doesn't seem to be a solution everyone's in agreement with - lots of internet accounts of people replacing master cylinders yet the problem continues.
I'm all ears on what to do...and anyone know about a clutch position switch resent for manual transmissions?
Markilepsy
S4 (B8 Platform) Discussion
12
11-26-2018 07:49 PM
yellow360f
01-03-2008 05:52 AM
s4pat
9
09-30-2003 04:36 PM
white951
11-22-2002 08:39 AM
