Navigation Not Working
I have a 2013 S4 and the navigation isn't working. When select it, it just sits there trying to updating and never turns on. These are all the things I've tried so far without any luck...
- hard 3 button reset multiple times on different days
- had my local shop see if there were any codes they could see with their scanner
Any suggestions are welcomed. Thanks
Does the MMI screen work? Did Navigation it ever work while you had it? Can you go into it to see what the most recent Navigation update / version you have for your car through settings? Also, may want to double check connections in trunk and behind MMI to ensure connections are tight (everything from the power to the gps antenna, to other harnesses). Does this car have anything aftermarket wired to it (like radio, amp, etc)?
John Turner
12-23-2016 12:10 AM
BiturboA6
05-05-2010 02:51 PM
