S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Navigation Not Working
Old 03-28-2017, 04:32 PM
bifffairburn12's Avatar
Default Navigation Not Working
I have a 2013 S4 and the navigation isn't working. When select it, it just sits there trying to updating and never turns on. These are all the things I've tried so far without any luck...
- hard 3 button reset multiple times on different days
- had my local shop see if there were any codes they could see with their scanner
Any suggestions are welcomed. Thanks
Old 03-30-2017, 07:16 AM
Banned
DrGP's Avatar
Might need an ecu reprogram? Just a guess
Old 03-30-2017, 03:49 PM
AForePlayin'03's Avatar
Has the four year warranty expired? If not, take it to the dealer before it does.
Old 04-03-2017, 09:12 AM
red1bw's Avatar
Does the MMI screen work? Did Navigation it ever work while you had it? Can you go into it to see what the most recent Navigation update / version you have for your car through settings? Also, may want to double check connections in trunk and behind MMI to ensure connections are tight (everything from the power to the gps antenna, to other harnesses). Does this car have anything aftermarket wired to it (like radio, amp, etc)?
Old 04-11-2017, 09:28 AM
ojmcneill's Avatar
Antenaes on these are notoriously bad. Might have a start with that. Mine's going in tomorrow to replace the antennae. Made it in just under the warranty wire.
wfroehlich
Q7 MK 1 Discussion
07-23-2017 06:32 AM
John Turner
12-23-2016 12:10 AM
MikeS6
S6 (C7 Platform) Discussion
08-21-2016 07:51 PM
BiturboA6
05-05-2010 02:51 PM
Bustter
05-31-2007 02:36 PM
Quick Reply: Navigation Not Working
