New B8 S4 with S-tronic design defect
I have a 2011 S4 with an S-tronic transmission with a design problem. It was verified by my Audi dealer.
If you wish to find out if your DSG/S-tronic transmission has the same design defect, check it out as follows:
Put your transmission in manual mode. Under wide open throttle, accelerate through first gear and shift out of first gear at 6100 or higher (up to 7000 redline). Stay at wide open throttle in 2nd gear. If your car has the design defect, it will shift out of second gear on its own, between 4000 and 5000 rpm!! Obviously, this is not what Audi intended. I can take the car to redline in any other gear--just not 2nd. The defect is in the mechatronic unit, but replacing it only fixes the problem half the time.
If you check this out, please post your finding as a reply to this thread. I've already run across three B8 S4's with this problem.
Really? Is this just for 2011? I'm ordering a 2012 and this kind of bothering me.
I can't verify as my car is in the body shop. However, I have noticed while in manual mode, I go to shift manually out of first and the car shifts at the same time and I then find myself in 3rd. Very annoying.
What is more worrying is that if this is not the designed intent of the DSG why is there no clear fix. It almost makes M mode, dare I say worthless?
S tronic defect
can't find the problem until you own it and have driven it
a thousand miles.
[QUOTE=tobias;24230568]I have a 2011 S4 with an S-tronic transmission with a design problem. It was verified by my Audi dealer.
If you check this out, please post your finding as a reply to this thread. I've already run across three B8 S4's with this problem. Hard to find this issue with a car not broken in.
Oh and I don't have the above issue on my 2010...
