One Week and my S4 is raining Faults!
Hi!... im just new around here.
I really found this a very useful forum.
Well, I don't know what to do. Last week I got my 2011 Audi S4 (60K miles) and everything was OK. Yesterday I was driving very slow, looking for an adress and when I was going backwards really slow, the car just started beeping everywhere, all lights went off, Traction control, ABS and Breaking lights where the only ones that remained in dashboard. Also was flashing the parking sensor butto, also beeping. The engine remained on, limited to 1.000 RPM but the display in dashboard was in off too (The one that shows the speed, gear, etc.), so no error was visible.
Check engine is the only one that remains after starting again the engine. It always starts again and remains ok for a while. The only thing that I have linked is that it happen more often when I turn AC on.
I think thats it. A friend of mine took a scan from it. Please help!!! Dont really know Audi cars and I really wasn't hoping that a car like this could fail so fast. All revisions are made in Audi until 60K miles.
SCAN:
VCDS Version: Release 12.12.3 (x64)
Data version: 20140822
Saturday,05,March,2016,12:44:16:33490
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 1B 2E 36 42 46 47 52 53 55
56 62 72 77
VIN: WAUZZZ8K7BA008517 Mileage: 101650km/63162miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAKA) Labels: 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 C HW: 8K0 907 551
Component: 3.0T SIMOS84 H07 0002
Revision: --------
Coding: 0104000C240F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551C 001002
ROD: N/A
VCID: 316F639F60AB8896243-8064
No ASAM data for: "EV_ECM30TFS0218K0907551C" (AU48)
3 Faults Found:
6619 - ROD - Unknown Error Code
- 00 [104]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 17
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:05
6233 - ROD - Unknown Error Code
- 00 [096]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:23
6550 - ROD - Unknown Error Code
- 00 [101]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:08
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K5 927 156 Q HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H03 0001
Revision: --H03--- Serial number: 0000000119
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03002
ROD: EV_TCMDL501021.rod
VCID: 479B2D47FE2F26261A7-8012
1 Fault Found:
18779 - Function Restricted due to Exessive Voltage
U1401 00 [104] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 40
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:08
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0050
Revision: -------- Serial number: --------------
Coding: 296508
VCID: 820D7C531D8D430E0D9-80D7
2 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:05
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4086
Hex Value: 0x1203
Hex Value: 0x22D2
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:23:47
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x5782
Hex Value: 0x0232
Hex Value: 0x02D2
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CH HW: 8K0 907 064 CH
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 050100
VCID: 78F99EBBCB5199DEA3D-802D
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:04
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01290520101034
Coding: 66002000
VCID: 8009765B1381511E1BD-80D5
1 Fault Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 16
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:04
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000555523
Coding: 2600D0914034AF311701000300001D0D0F1CC3480201016100 0000
VCID: 3C7142ABBFE975FE875-8069
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 020610 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Subsystem 4 - Part No SW: 8K0 907 410 HW: 8K0 907 410
Component: EHL205.06.02K H02 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941015404675
Coding: 10010D
Shop #: WSC 06342 000 00000
VCID: 48992E7BFB31295E13D-801D
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:08
Freeze Frame:
Temperature: 37.0°C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0GX3L$
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 44813A4BCF190D3EFF5-8011
Crash sensor for side airbag; driver side:
Serial number: 6334MSME540329747
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME5431204B4
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME7F622226J
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME766223228
Crash sensor for front airbag; driver side:
Serial number: 63732SME08632236T
Crash sensor for front airbag; passenger side:
Serial number: 63832SME0A631D1E5
No fault code found.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JF700075
Coding: 000036
VCID: 3E7548A3A9F567EEA91-806B
Component: E221 - MFL H02 0010
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:08
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:19:01
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 931 HW: 8K0 920 931
Component: KOMBIINSTR. H06 0258
Revision: 00000000 Serial number: EJE53NU5A
Coding: 0F0709002A000008010000
VCID: EBD331F70A07A246DEF-80BE
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G10527849C
Coding: 00C303
VCID: 810F735F188B5816143-80D4
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
1 Fault Found:
02252 - Generator
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 4
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:24
Freeze Frame:
Bin. Bits: 01111
Voltage: 18.90 V
Count: 6
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 397F5BBFB0DB40D69C3-806C
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010170894
Coding: 00581B00000000000000
VCID: 3B7341B7BAE772C68EF-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C12205E00410001
VCID: 53A3091732779A8676F-8006
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0131136561
Coding: 011A0E2200B945858030013280000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Subsystem 2 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS039 H06 0041
1 Fault Found:
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 19:30:56
Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34835001254003
Coding: 0203010302
Shop #: WSC 07502 000 1048576
VCID: 7EF588A3E975A7EEE91-802B
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52AD0C130D6D938E7D9-8007
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000530283
Shop #: WSC 00000 000 00000
VCID: 34616A8B97B9BDBE4F5-8061
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:23:47
Freeze Frame:
Voltage: 16.80 V
Count: 62
Hex Value: 0x02E0
Hex Value: 0x0082
Hex Value: 0x0101
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 06324 000 00000
VCID: 3069669BA3A1819E2BD-8065
Subsystem 1 - Part No: 8K0 941 329
Component: AFS-Modul links H02 S001
Subsystem 2 - Part No: 8K0 941 329
Component: AFS-Modul rechtsH02 S001
2 Faults Found:
Freeze Frame:
Fault Status: 00110001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:06
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:52:44
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 AC HW: 8T1 035 195 AC
Component: Symphony3 US H07 0351
Revision: 00000010 Serial number: AUZ5Z4J1219590
Coding: 040300820101850003DB070804
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 65
Mileage: 100847 km
Time Indication: 0
Date: 2016.01.11
Time: 14:43:57
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
00468 - CD-ROM Drive (R92)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Mileage: 100945 km
Time Indication: 0
Date: 2016.02.26
Time: 18:33:34
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C12204000210001
VCID: 56A5F00321858FAE911-8003
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1401
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 E HW: 8T0 862 335 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005200488
Coding: 0010390
VCID: 3C7142AB7FE975FE875-8069
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 66
Mileage: 101659 km
Time Indication: 0
Date: 2016.03.05
Time: 11:26:45
End ---------------------------------------------------------------------
SCAN:
56 62 72 77
Revision: --------
ROD: N/A
3 Faults Found:
- 00 [104]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:05
- 00 [096]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:23
- 00 [101]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:08
Coding: 000001
1 Fault Found:
U1401 00 [104] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 40
Mileage: 101614 km
Date: 2016.03.04
Time: 18:18:08
Coding: 296508
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:05
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4086
Hex Value: 0x1203
Hex Value: 0x22D2
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:23:47
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x5782
Hex Value: 0x0232
Hex Value: 0x02D2
Hex Value: 0x00FF
Revision: 00002001
Coding: 050100
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:04
Coding: 66002000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:04
Coding: 00FD11
Coding: 025028
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:00
Coding: 10010D
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:08
Freeze Frame:
Temperature: 37.0°C
Coding: 000036
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:08
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:19:01
Coding: 00C303
1 Fault Found:
02252 - Generator
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 66
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:24
Freeze Frame:
Bin. Bits: 01111
Voltage: 18.90 V
Count: 6
Revision: 00000000
Coding: 020202
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 19:30:56
Coding: 0203010302
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:23:47
Freeze Frame:
Voltage: 16.80 V
Count: 62
Hex Value: 0x02E0
Hex Value: 0x0082
Hex Value: 0x0101
Coding: 0000019
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:18:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 101614 km
Time Indication: 0
Date: 2016.03.04
Time: 18:52:44
Component: Display
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 65
Mileage: 100847 km
Time Indication: 0
Date: 2016.01.11
Time: 14:43:57
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Mileage: 100945 km
Time Indication: 0
Date: 2016.02.26
Time: 18:33:34
Coding: 0010390
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 66
Mileage: 101659 km
Time Indication: 0
Date: 2016.03.05
Time: 11:26:45
Can you have your friend with VCDS check the condition of the battery? I suspect it is power related fault. Not sure but best to verify if the battery is OK or not before looking at other causes.
Battery or maybe alternator. You can see voltage spiked to 16.8V.
If it's an original battery it's about due for replacement anyway.
I hope you are right. I'm really scared after seen all that errors. My friend left the scanner with me but don't really know how to measure the battery. Where and what should I read?.
Today I drove 200 miles with AC off and no problem at all. I was scared to turn it on as it brings the issue when Im on a red light or still. I really appreciate your help!
AudiWorld Uber User
Check your voltage regulator. it might be trying to charge the battery too hard or stuck fully on.
Hi.. I managed to diagnose the battery...
I performed several tests and the only indicator that started to change after I turned the AC ON, put reverse, Lights, etc. Was the "Battery Current". What could this be?.. It started from 18A to -9A and also when during the turning on of the car it shows -130A. Is that normal??
Here are the pics. Thanks again for your help....
Engine Off:
Just turned on:
Engine On / AC On
Engine On / AC On / Reverse + Parking
Engine On / AC On / Reverse + Parking + High Revs
Engine On / AC On / Reverse + Parking + High Revs.. few mins later
Engine Turned Off
During the turning on of the engine:
Well thats it... any ideas??
thanks!
Engine Off:
Just turned on:
Engine On / AC On
Engine Turned Off
thanks!
Over Voltage
So What fixed the problem? I'm having the same issue...
[QUOTE=Siderick;24784752]Hi!... im just new around here.
gixxer//s4
08-25-2003 07:05 AM
