S4 '13 wheel alignment outside dealership - AudiWorld Forums
S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Old 04-05-2014, 12:43 PM   #1
Default S4 '13 wheel alignment outside dealership
Today I went to 3 different places (CarX, NTB and Midas) and they were not able to offer a wheel alignment because none of them have the software with the settings for my 2013 S4.
Does anyone know where I can take my car for a simple tire rotation, balancing and alignment other than the dealership in Austin or anywhere in central TX ?
Fabio Corsi is offline   Reply With Quote
Old 04-07-2014, 09:41 AM   #2
DrGP's Avatar
And you don't want to go back to the dealer because??? And why do you think you need an alignment and balance?
DrGP is offline   Reply With Quote
Old 04-07-2014, 11:11 AM   #3
I do rotation, balancing (if needed) and alignment every 5k miles.
I was not satisfied with their alignment the last 2 times I took my car for service... And for less than what they charge I can get a lifetime alignment in any of the places I mentioned in my post.
Just spoke with Audi and they confirmed no other place will be able to perform alignment due to all electronic and systems resets that are needed.... Which confirms what NTB guy told me.
Old 04-07-2014, 01:06 PM   #4
DrGP's Avatar
I have never had to do an alignment on any of my cars. All the tires have worn evenly. But I understand that it is sometimes necessary. But every 5K? Yes I rotate my tires evry 5k but don't balance them as long as there ate no vibrations . But if I felt I need to balance or align, I would only use a shop with Hunter GSP equipment. You can goole that and they will give you locations that have that equipment.
Old 04-07-2014, 01:33 PM   #5
snagitseven's Avatar
IMO, every 5k miles for an alignment would be excessive and unnecessary. The only time I would pay for an alignment check is if I hit a deep pothole hard enough to damage a wheel or tire and felt the car pulling to one side or if I were to notice any uneven tread wear. Otherwise, at $150-$200 for a properly performed 4-wheel alignment, it would be a waste of money. The only time in 13 years and four Audis that I had the alignment checked ($150 5 years ago) was after I had to replace a severely damaged wheel and it was to spec.
As to balancing, most any Audi service center has a Hunter Force Balencer these days. My dealer charges about the same as my local tire shops that have the machine, about $25 per wheel. It's key the machine be propely calibrated and the operator trained to do it right. I've been on both sides of that coin.
snagitseven is offline   Reply With Quote
Old 04-08-2014, 11:13 PM   #6
Just got a new set of tires on my '13 and was thinking about doing an alignment. The car is not pulling to one side or another. The OE tires wore on the outer two ribs of the tires. This is my first AWD car and figured the AWD system may hide alignment issues.
safetywork is offline   Reply With Quote
Old 04-09-2014, 03:58 AM   #7
I don't think an alignment with new tires is unreasonable but an alignment every 5K miles in the absence of an issue seems excessive and a waste of money. Even if they could do it, I'd be concerned NTB, Midas, etc. would screw it up if someone gave them that many opportunities as well.
RickFLS4 is offline   Reply With Quote
Old 04-09-2014, 09:01 AM   #8
DrGP's Avatar
If you notice uneven wear on the current tires, then an alignment definitely in order. If they wore evenly, I personally would not bother.
Thread Thread Starter Forum Replies Last Post
Audi Q7 Winter setup OEM S-line 20" Bridgestone Blizzak 275/45R20 rayjr13 Parts For Sale 10 04-12-2016 05:43 PM
New Q7 2015 TDI slight shimmy dealer calls it road feedback? Quetzal Wheels & Tires Discussion 3 09-23-2015 08:50 PM
When to replace shocks and struts - Wobble at 20mph/40mph ZPA117 A4 (B8 Platform) Discussion 4 09-08-2015 12:55 PM
Mechatronic and Sport Differential issues wjhpilot S4 (B8 Platform) Discussion 0 09-04-2015 02:43 PM
95 Cabriolet Wheel Alignment Issues. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 09:48 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
