Tire Question
Tire Question
Good day - I have a tire question and thought I would get some input. I have a 2011 S4 with 17,450 miles. I have a tire problem on the rear tire that is not repairable. I ordered two replacement tires for the rear and planning the leave the front tires alone. My question is this: with the quattro system will there be any performance/drivetrain issues with replacing just the rear tires, or should I replace all four. They are rather pricey, so it's worth the investigation.
Thank you for any input you may have regarding this problem.
Don't do it!
The Quattro system will immediately stop functioning, your warranty will be voided (TD1), and the wheels may fall off if you exceed 55 mph.
I would advise replacing all five tires to avoid any performance/drivetrain issues.
Banned
The spare is a donut! So he only needs 4(just continuing your line of thought) Nod,Nod, Wink, Wink. Just buy 1 tire from Tire Rack. Have them shave the tread to match that of your current tires and be done with it. It will save you money and no worries about different diameter tires.
As published in their vehicle owner's manual, Audi states "rolling radius of all 4 tires must remain the same" or within 4/32-inch of each other in remaining tread depth. If that's the case, no shaving of the new tire would be necessary.
As mentioned above...
... the question is the degree to which the fronts are worn. 18K is pretty good for performance rubber. We get about 10K from our S4/S5/RS5. If you rotate the tires, you can better distribute the wear. Audi's are nose heavy and understeer - they are brutal on front tires. Also, when you replace all four, you can negotiate for the best tire deal. I recently did all four on both cars and there were huge differences in the discount, depending on brand. I put Continental Sport Contact Extreme on the S4, but went with a harder compound then the original. On the S5, I put Michelin Super Sports as I like the dry weather handling and the progressive way the tires give up traction.
Happy Motoring
Eric'
Happy Motoring
Eric'
Thank you for the helpful comments, what my question should have asked was if you have a (one) tire of a different diameter on long term - either front or back - would it effect either the handling or long term wear on the Haldex differential. I replaced both rear tires with the Dunlops, I will switch to Michelin's in the future. Thank you again for the thoughts.
bauhaus312
18
08-30-2005 07:47 PM
shaker
07-02-2001 08:11 PM
