2000 S4 idle fluctuating
Car is idling at or around 1000rpm but fluctuating between 800 and 1100. constant oscillation. can someone lend some advice?
throttle body
i may not be any help. but my first a4 did that and i had to replace the throttle body. '
now my s4 is doing it to and i was scared to ask the forum because every question has been asked before and the old locals ( and some new people who post alot) usally tell you to search past posts.
anyways it was the throttle body on my a4
s4 crank no start/ hard start??
issue has changed to a crank no start/ hard start. Will only start with gas pedal floored and keep it running with revs. Then the EPC light and Check Engine light come on, power is very limited and it stalls due to lack of throttle response to keep it alive. MAF was checked, and appears to be functioning properly; also swapped in a known good one.... no change in performance... 60k miles, tiptronic.. previously EPC light would come on [and limit power intermittently] with no supporting drivability issues.
VermontAudiMan
12-21-2007 04:09 AM
lolyf
06-05-2006 08:01 PM
Skewoooot
07-22-2004 07:48 PM
