2000 S4 Misfire Problem.
Replaced the TBB (034 silicone), Bypass Valves (with 710n) and after run coolant pump(034 Pump delete) over the weekend. Now I'm getting misfire problems. I also replaced the 2 plastic Y type connectors behind intake manifold with brass and the brake booster vacuum line.
I STFA and subsequently triple checked all my clamps. I tested for vacuum leaks by spraying brake cleaner on the vacuum connections. (Hoping to get a momentary increase in idle as an indication of a leak.) Didn't find any leaks.
Car is missing and holding back under load, check engine like blinks under load.
I'm hoping someone could help. I don't have access to a vag.
2000_Audi_S
New England Discussion
05-28-2007 03:39 AM
E Vader
05-30-2006 12:16 PM
