2001 Audi s4 a/c fan wiring problem.
Old 06-27-2014, 09:24 PM
techouse22's Avatar
Default 2001 Audi s4 a/c fan wiring problem.
First off let me say that I am new to the forum and to Audi and would like to thank you all for the valuable info I have received on this forum which is why I decided to join your community.
Now for my problem, I have a 2001 Audi s4 that I just bought. I started trying to fix the a/c and after I checked the compressor clutch to make sure it is working ( it is ) and I replaced the pressure switch I realized that the fan on the front and on the left side of the radiator are not coming on. I looked around and found a two wire connector that runs to the fan along the bottom of the radiator that I can not find the other end to. it is long enough to reach the top of the car by the power steering reservoir but I do not see the other end of the connector. does anyone have an idea were this might go?
Old 08-12-2014, 05:50 AM
Skribbs2000's Avatar
Default Fan Control Module
Start with checking the relays, then fans, but most likely its the fan control module.
Audi B5 S4 2.7T Engine Cooling Fan Control Unit - 8D0959501D - Auxiliary Fan Control Unit - ES#433024
#8D0959501D
Janis Graholskis
05-22-2019 05:27 AM
guite42
01-28-2018 09:56 AM
sugaryling
17
08-21-2007 05:17 PM
zanford
03-07-2005 11:05 AM
christmcd
03-01-2005 05:52 PM
Quick Reply: 2001 Audi s4 a/c fan wiring problem.
