View Poll Results: why won't mu2001 S4 with triptronic shift into 4 th or 5th gear
could it be a shift soliniod
0%
could it be a bad clutch pack
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
2001 S4 triptronic isn't shifting into 4th &5th gear
I have a 2001 S4 with a APR ecu aftermarket exhaust,Forge diverter vavles.
The problem I'm having is that ocassionally my triptronic would go into limp mode and I would have pull over turn it off and then turn right back on and it would be fine.
So the car seem to be running great one day then the following day it wouldn't go into 4th or 5th gear and if you did put it in either of those gears it will pretty much free rev.
And like I said the day before all gears worked fine no slippage that would warn me of clutch packs being worn out or anything.
Also my heater core was leaking water onto the passenger floor which I hear is where the tcu is located and if it gets wet it can malfunction.
And the torque converter was replaced about 6 months before I bought it
Could it be syloniod?
kaboom
05-29-2016 07:17 PM
Tyler Stache
03-29-2016 04:19 PM
